| Home > General Chat > rust | |||||||
269 Posts Member #: 396 Senior Member sheffield/rotherham |
2nd Oct, 2005 at 07:19:08pm
any1 tell me whats the quickest and most efficient way or removing rust, ive been sat today for bout 2 hour rubbing down bits with just plain old paper and its taking for ever. is there some kind of tool i can use to make the job quicker? speed is the best rush i have ever had!!!
![]() 341 Posts Member #: 259 Member grays, essex |
2nd Oct, 2005 at 08:02:36pm
unfortunatly lanxter paper is the only way. Using a grinder could end up causing more trouble and more holes! Sometimes if the rust patch is only surface then an electrical orbital sander will do the trick, otherways, its just braun n patience! As for covering buy yourself a spray can from halfords of any colour. Try not to use primer because primer is porus and will let the water through.
it may b small but it purfectly formed
928 Posts Member #: 65 Post Whore South Yorkshire |
2nd Oct, 2005 at 08:06:55pm
I found a thing called a Monti (sp?) brush works well. Fits in an electric drill. There's one with angled bristles that cleans or polishes depending which direction you run it.
2nd Oct, 2005 at 08:11:21pm
2 ways i use no1 is wire wheel on a drill and no2 is you can get wire wheels which fit onto your angle grinder and i find these are very effective if you have acess to a compressor sand blastings probably better. then treat it with rust killer, then paint no longer a series, but still 1.3 turbo.
2nd Oct, 2005 at 08:15:27pm
when you paint on the rust killer gel like substance are you supposed to sand and remove it all afterwards? |
2nd Oct, 2005 at 08:29:42pm
On 02/10/2005 20:02:36 1976_mini said:
unfortunatly lanxter paper is the only way. Using a grinder could end up causing more trouble and more holes! Sometimes if the rust patch is only surface then an electrical orbital sander will do the trick, otherways, its just braun n patience! As for covering buy yourself a spray can from halfords of any colour. Try not to use primer because primer is porus and will let the water through. si. sorry cant agree on that! grinding the rust away is the only way of preventing it coming back if yo make the hole bigger thats generally because it was that big anyway, i usually use a knotted cup brush or 115mm flap wheel as these are less aggressive than a grinding disc and only slightly more work to use Crystal Sound Audio said:
![]() 2641 Posts Member #: 19 Post Whore newcastle |
2nd Oct, 2005 at 09:08:10pm
carbon fibre , works for me Everyone knows that instructions only have to be read if the thing doesn't work....
3rd Oct, 2005 at 09:32:52am
I agree with wolfie Team www.sheepspeed.com Racing
