| Home > Help Needed / General Tech Chat > Stripped drain plug, and repaired wrong...some advice | |||||||
6 Posts Member #: 10673 Junior Member |
2nd May, 2020 at 02:57:28am
its a 998 from teh 80s. When I got the car it was stripped, so I got the correct helicoil and drilled/tapped it, no issues...except for the fact I didnt do it straight, not my proudest moment. It happens to the best of us.
2nd May, 2020 at 06:09:29am
If the case is off could you just get it tig welded and re-tap for the standard thread? Or just get another case for the hassle it will cause. On 7th Oct, 2010 5haneJ said:
2nd May, 2020 at 10:54:01am
That might work, depending how pissed it is, how pissed is it?
2nd May, 2020 at 10:54:19am
3rd May, 2020 at 10:58:33am
I think there’s plenty of room round it from memory, I would just go up to a bigger size, probably use something metric, drill out and helicoil it, square this time!!
6th May, 2020 at 05:23:13pm
My sump plug is the same; helicoiled on the piss. I tried dowty washers, tape, etc.
8th May, 2020 at 05:07:51am
I got the gearbox torn down and really looked at it. Looks like I can shave the wind off around there the sealing surface is so I can just flat file the angle in. In the end if it's 1 deg off and seals flat who cares. There is so much meat in the area I'm not worried about it. And if down the line it's really an issue it would have to be plugged, welded and machined flat again anyway. Should take me less than an hour I think and the repair should be fine |
16th May, 2020 at 12:20:34am
Fixed! Cut off the ears around the drain plug so I could get a flat file on it, then just filed an angle into the sealing surface to match the angle of the drain plug. Didnt take much, tool all of 30 minutes. Done and done!
19th May, 2020 at 04:21:41pm
looks like you've sorted it. Had the same issue with mine and used a dowty washer to solve it |
