| Home > General Chat > Pre-Planning for first Start Video(Help?) - Classic Mini DIY | |||||||
5 Posts Member #: 12106 Junior Member Charlotte, NC, USA |
9th Feb, 2021 at 12:00:46am
Doing some pre-planning for the first start of the turbo build and I am trying to make sure I cover all the "best practices" when attempting to start a carb turbo build for the first time. Would love some input from the pros!
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
9th Feb, 2021 at 08:40:10am
Welcome to the forum,
Edited by shane on 9th Feb, 2021. |
10th Feb, 2021 at 08:45:30pm
On 9th Feb, 2021 classicminidiy said:
Doing some pre-planning for the first start of the turbo build and I am trying to make sure I cover all the "best practices" when attempting to start a carb turbo build for the first time. Would love some input from the pros! So far I have: - Confirm fuel pressure - Plumb actuator without a bleed valve/boost controller - Doublecheck all vacuum feeds, seals, and connections - Validate oil pressure - The base setting for the carb with BDD needle? (could use some input here) - Ensure you have a safe base map on your ECU - Ensure your timing is correct (if not using ECU) (could use input here on base timing to start) Hi Cole, Mate the fact your asking soooo many std questions on fb and now here.... but you run a YouTube ch that brings an income, where you tell people how to do this stuff and build engines. Is it just me that sees it as a little odd? I have started posting on Instagram also my name on there is turbomk1golf
10th Feb, 2021 at 08:56:06pm
ahhhhhh i thought i recognised the name, I do like watching the youtube videos
Yes i moved to the darkside |
