| Home > General Chat > For those with milling machines - annular cutters. | |||||||
6th Apr, 2021 at 02:35:31pm
If you’ve not got a set of Annullar cutters, you need to get on eBay and buy a set.
6th Apr, 2021 at 07:50:05pm
Any links to the ones you bought Dave? To help avoid shit quality ones.
7th Apr, 2021 at 09:24:18am
These look good 👌 I have started posting on Instagram also my name on there is turbomk1golf
7th Apr, 2021 at 01:58:57pm
Three different brands here Phil - the 1-7/16 is Wansui Probor, the 1-1/4 and one 1-3/16 was Steel Dragon, and the last 1-3/16 was AC tool. All Chinese obviously, but I can’t tell them apart in quality.
On 6th Apr, 2021 Turbo Phil said:
Any links to the ones you bought Dave? To help avoid shit quality ones. Phil. Edited by turbodave16v on 7th Apr, 2021. On 17th Nov, 2014 Tom Fenton said:
7th Apr, 2021 at 07:14:38pm
These are also called rotary broaches ?
7th Apr, 2021 at 09:57:59pm
I’ve never heard that term; the only other term I’ve heard then described as is a ‘slugger bit’.
8th Apr, 2021 at 08:22:36am
I think broaching is a general term for a type of machine cutting, of which rotary broaching is one method that uses this type of tool. There is also linear broaching that is used for things such as cutting teeth on a gear, or a slot such as a keyway. Edited by metroturbo on 8th Apr, 2021. |
2647 Posts Member #: 1246 Post Whore Lowestoft, Suffolk. |
8th Apr, 2021 at 08:26:17am
On 7th Apr, 2021 TurboDave16V said:
I’ve never heard that term; the only other term I’ve heard then described as is a ‘slugger bit’. Not sure if what you’re talking about looks more like this, I discovered these from the electricians at work Who use them for putting holes in panels. They make an absolutely perfect cut with no deburring - I certainly can’t say that about the old school hole-saw type. ![]() Shane |
8th Apr, 2021 at 09:33:13pm
That's just a variation of a holesaw, albeit looks like it has carbide tips in it for hopefully a cleaner cut. As regular HSS holesaws are pretty terrible.
