Home > Help Needed / General Tech Chat > detonation has stuffed engine
RED850
Member #: 89
Sydney Australia
does anyone here us a programable ignition system? if so was it an off the shelf item or does anyone know of any off the shelf kits available?
i stripped my engine last night to find the forged pistions to be severely damaged from detonation and even had a broken top ring on cyl one in about 12 peices.
so i guess it will coem down to a few things, one beign to far advanced, two being poor fuel quality, and three beign to much boost with no intercooler.
so my first step is to rebuild the engien with new pistons etc etc then fit new ignition system and cooler.
has anyone used the omega forged pistons from Avonbar? any thoughts on them?
179hp on 12psi 1293cc of pure A series
14.0et @101 mph
Could you not hear it detting under load?
If it was bad enough to do all that damage I am suprised you did not hear it?
RED850
Member #: 89
Sydney Australia
yeah so am i, the motor is nt quiet neither is the exhaust but i still did not hear anything and the motor has been in for over 5 years.
oh well thems the brakes, time to start again.
14.0et @101 mph
drop the C/R ratio to around 8.5:1 run optimax fuel
fit efficient intercooler
it suprises me you did not hear the onset of detonation! my mini has a straight through exhaust and i am 50% def in one ear*laughing*
& i can hear it!
i suspect you did not realise what you were hearing for.*frown*
if you hear a rapid machine gun at a distance under the bonnet lift you foot!.....................
i was lucky only wiping two head gaskets out
then followed the above advice !*wink*
mapped ignition is the way to go*happy*
good luck
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Well you cant hear most det so it doesnt surprise me...
Alex
AlexF
AllanMcD
Member #: 414
Dalbeattie Scotland
I run programable ignition and high compresion I bought a megasquirt pre asembled as I wanted the future option of fitting fuel injection.
I have done over 6000 miles since fitting the ignition and new pistons , running 9-1 comp and a max of 10psi boost returning up to 43 mpg I run little advance when boosting over 5psi but the clever bit is you can set it to exacly what you want knowing it is right.
I can get you a contact if you want
I couldnt hear the det when my first pistons went but when I fitted the megasquirt I was listning for it as I set the advance a bit high and I could hear it ( mostley up hill at around 3000rpm 6-7 psi )
I then played around with it until it stoped then set the advance a couple of deg less to be safe.
Edited by AllanMcD on 7th Oct, 2005.
http://www.rabdunn.co.uk/
The slightest amount of Detonation over 5(!) years will take its toll eventually!
Oh well, lesson learnt. You've a plan of action that is basically sound, so built yourself a goodun!
RED850
Member #: 89
Sydney Australia
yeah sounds about right, i have just sent an email to boostengineering@earthlink.net about the megasquirt, is that the contact you have Allan?
is it easy to tune and play with, I have heard it is a great system.
how did you fit the trigger disc to the harmonic balancer?
please see pic of piston
14.0et @101 mph
ouch!
andeh
Member #: 97
Near Daventry, midlands
Ditto on the ouch!
wow - it's even goine past the top-ring!
Richie
Member #: 628
it looks real pretty lol what octane fuel are u running ? i know when i did N/A engines, anything less than 105 octane would screw me engine. was running serious compression though
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
AllanMcD
Member #: 414
Dalbeattie Scotland
bill@shurvinton.fsworld.co.uk is the contact I used and the service was briliant it is very easy to play with.(sorry I only just checked this thead as I usualy just use the front page)
You just weld the triger wheel on to the puly I asume the harmonic balancer is the pulys tech name it dosnt mater that the puly is rubber is the anty vibe or whatever it is.
Allan
Edited by AllanMcD on 18th Oct, 2005.
giallofly
Member #: 164
The Stig..
Newport Pagnell
Was the engine ever rolling road tuned?
gt1310
Member #: 678
Sydney, Australia
God dam dude... Sorry to hear.. :(
O well maybe I will have evil up and going by the time your going again. :)
you showed those pics to Doc?
www.users.tpg.com.au/codyabel/gt1310
www.users.tpg.com.au/codyabel/evil850
turbo hogster
Member #: 178
stowmaket suffolk
i bet thats number 2 or number 3 piston.
if its going to go its one of these thats why i did make my head slighlty larger chambers for 2 and 3.
RED850
Member #: 89
Sydney Australia
over here in Oz we do not get many rolling roads?dyno's its just not that common but do not worry this one will be tuned that way, this engine had been in the car for over 5 years now so its done pretty well for the flogging it gets and the high boost level.
i have now recieved some new parts for the build up
just waiting on a few more bits too.
14.0et @101 mph
Ahhh, You're putting little red x's in the engine are you?
RED850
Member #: 89
Sydney Australia
sorry im lost
little red x's????
14.0et @101 mph
Pics work for me........
They do today!!!
Crank bolts look interesting - source?
RED850
Member #: 89
Sydney Australia
crank bolts from MED
14.0et @101 mph
