| Home > General Chat > Dismantling T2 - word of warning to you all!!! | |||||||
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
3rd Feb, 2004 at 01:31:20pm
Got a cheap T2 that needed reconditioning the other day, and started to take it apart last night for a good inspection. It was all coming apart reasonably, bolts were a bit tight but to be expected with the temps that these things run at, the turbine housing came off okay, which then brought me to undoing the nut on the end of the shaft in front of the compressor wheel so I could withdraw the turbine wheel and shaft out the back. I clamped the boss on the end of the turbine wheel, and started to undo the 12 point nut, and BINGO IT SHEARED THE SHAFT!!! |
3rd Feb, 2004 at 02:26:23pm
Yup somtimes they do that, hence why a recon turbo from turbotechnics isn't cheap!
AlexF |
3rd Feb, 2004 at 02:34:55pm
Definitely not cheap thats for sure, I remember when I used to have my 5 turbo I was thinking about a new turbo for some extra boost, and they are definitely expensive even for standard.
Edited by dan on 3rd Feb, 2004. |
3rd Feb, 2004 at 03:04:52pm
Ive also heard that casing cracks on T2's are very common. Especially where the wastegate seals onto the casting. Not run mine with the T2 yet so havent found out if it makes any difference. Pretty sure the wastegate doesnt seal very well anyway! |
3rd Feb, 2004 at 03:37:29pm
they all crack....
AlexF |
3rd Feb, 2004 at 03:54:52pm
Bit of a design flaw i think!
3rd Feb, 2004 at 08:13:36pm
4th Feb, 2004 at 08:51:04am
Hello there Fab, I undid the nut on the shaft in the normal anti-clockwise fashion. Is this wrong, are they left-hand threads on the shafts.
4th Feb, 2004 at 09:40:31am
You would feel silly if it was a left hand thread! |
4th Feb, 2004 at 07:15:30pm
yes , Dan, it is an unbolt clockwise thread , or as you saying a left hand threads on the shaft.
4th Feb, 2004 at 08:13:21pm
Oh well, at least I now know as do a few others. Thanks for the offer of a spare shaft fab, but I think i will re-assemble the casings and blank of the centre piece of the turbo and use when I run the engine in.
5th Feb, 2004 at 06:51:53am
Sorry dan ,
Edited by fab on 5th Feb, 2004. |
