| Home > Help Needed / General Tech Chat > bracing prior to fitting box? | |||||||
![]() 439 Posts Member #: 176 Pre-op Transvestite Felixstowe, Suffolk |
12th Oct, 2005 at 01:46:38pm
hey guys, long time! hope everyone is well :) NO LONGER A <3 lover of BOLT-ON plastic <3 .... (and DOUBLE proud of it) |
12th Oct, 2005 at 02:05:56pm
No need to bother mate. Just make sure the car is on an even level surface before you start. Probably worth changing the subframe mounts to solid before fitting box if you are worried about it, but honestly no big problem. Another option is to place the car on stands at the front, under the subframe.
12th Oct, 2005 at 06:28:18pm
yeah as tom said, i didnt bother with mine and its fine, only thing i did was get my friend to spot weld the box in first before seam welding it fully. |
12th Oct, 2005 at 11:05:54pm
cheers guys! if the weather isnt too shabby i shall hopefully get this done tomorrow, i'll let you know how it goes :) NO LONGER A <3 lover of BOLT-ON plastic <3 .... (and DOUBLE proud of it) |
