Home > Help Needed / General Tech Chat > idler gear
benny hill
Member #: 707
pontefract
hi all, just wondering if you can fit the a-plus idler gear into the pre a-plus gearbox?
do you just have to change the idler gear bearing?
I do beleve we are on the eve of destruction
NO!
You have to change ALL the drop gears to the A variety.
The tooth profile is different from the A to A+ gears, this includes drop gears, gearbox gears, and CWP.
You can only use them as sets, although it is perfectly possible to mix and match, e.g. A series drop gears with A+ gearbox and final drive gears.
The other difference in the drop gears is the shaft size on the idler, as you have probably discovered!
Edited by Tom Fenton on 17th Oct, 2005.
benny hill
Member #: 707
pontefract
sorry let me be a bit more clear, i want to fit some a-plus drop gears to a unit that i am building,the gearbox that i want to use is an a-series, will the drop gears fit if i change the idler gear bearing? sorry for the mix up,
regards benny
The A series idler will go into an A+ case with an adaptor but the A+ will not go into the A series (unless you machine it to the right size) as the bearing and shaft are larger diameter.
turbo hogster
Member #: 178
stowmaket suffolk
im pretty sure that a a series 1275 idler is the same as the A+ item its just the 998, 1098, 850 boxes was different but i may be wrong but im pretty sure.
Nick
Member #: 154
Midlands
i think the A series idler shaft is 1/2" and the A+ is 7/8"
I know you can definately get a kit to fit the A idler gear into an A+ box, but no sure about that other way round.
You're WRONG, Sorry :)
All four sync A boxes have got the same idler.
I'm fairly sure that the A are 3/4" and the A+ 7/8"?
For what it has to do, a 1/2" shaft on the idler would be tiny!!
Mike
Member #: 107
Sunny Sussex
y tom your right, just measured them as i'm in the same position for this thread, i have an A+ set and the box has a 3/4 idler bearing. i presume i can simply swap it for a 7/8 bearing?
also the final drive shaft nut is smaller than the A+, anyone got a minispares partnumber for the A series one as i cant find it.
Edited by Mike on 19th Oct, 2005.
You can't just swap it, as the hole bored in the casings is a different size.
It is possible to go the other way, e.g. A idler into A+ box, but not possible to go A+ idler into A box.
To go A idler into A+ box you need to use a conversion bearing available from Minispares.
Edited by Tom Fenton on 19th Oct, 2005.
