| Home > Help Needed / General Tech Chat > Clutching at straws | |||||||
17th Oct, 2005 at 04:39:50pm
So, the time has come to check the clutch I have before bolting the flywheel up. I lapped the flywheel in as a start, and then went about checking the level/attitude of the spring.
17th Oct, 2005 at 04:53:09pm
From what I have read mate, you need to get the whole assembly together in a fly press or similar, so that you can manually compress the spring.
17th Oct, 2005 at 04:54:27pm
Makes sense. I suppose you need to support flywheel round the edges and then manually compress spring.
17th Oct, 2005 at 04:58:47pm
Yes you need to let the backplate move, I suppose you could use a pillar drill with a pull down arm to the same effect............ |
