Home > Help Needed / General Tech Chat > Putting Boost through an SU
Chris1200t
Member #: 727
Gday i was just woundering if it was possible to run boost through an Su and if so what needs to be dont to the su fo it to handel the boost.
Edited by AlexB on 24th Oct, 2005.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
hello and welcome....
Yes you sure can, in fact thats the was BL did it on the Metro Turbo and the Montego/Meastro turbos!
The easiest was is to get a turbo SU (ebay or new from Burlan (SP)). But it is possible to convert a stand HIF to turbo spec with a little work and knowledge/skill.
Alex
AlexF
gt1310
Member #: 678
Sydney, Australia
[quote]and if so what needs to be dont to the su fo it to handel the boost.
[/quot]
Lost me there,, :)
www.users.tpg.com.au/codyabel/gt1310
www.users.tpg.com.au/codyabel/evil850
Chris1200t
Member #: 727
whoops its sposed to be "and if so what has to be (done) tot he su"
It's easy as long as you use the later HIF tpye with the 'internal' float bowl.
I'm sure you could use an earlier 'external' float bowl type, but as HIFs are easily available, why would you bother.
Wil
Chris1200t
Member #: 727
Wot would be the difference in using an internal flote or external.
cheers
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
one is a HIF (internal - fuel bowl under carb) the other the HS (external float chamber).
One workes well HIF 44 Turbo for example!!!
The other is very unlikly to without major mods.
USE AN HIF44 *happy*
Alex
AlexF
Chris1200t
Member #: 727
Thanks Alex where abouts can i get an HIF44 carby
cheers
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
http://www.burlen.co.uk/store.aspx
http://www.ebay.co.uk/
wanted ad on here....
Alex
AlexF
