Home > Wanted > Flywheel Locking Tool
I used one of these at Avon Park this year when I helped Jim change his clutch on the saturday night. It was a real useful piece of kit, I am getting close to needing to torque up the flywheel bolt on my own engine, so one of these would be useful, rather than wedging a screwdriver in the ring gear whilst pushing the torque wrench down with your foot.
Does anyone know where they are available from? Jim?
Dr. jinG
Member #: 368
Roseville, CA (USA)
I've found that a short piece of 1 3/4" angle iron wedges itself in the flywheel very nicely, and holds itself there for torquing...
1967 Cooper 's' Turbo build @ www.drjing.com
There's someone that has been floging them on evilbay for quite cheap.
8008236283
Mini 200+, I wonder if they post here.
Edited by Joe C on 24th Oct, 2005.
adam1330
Member #: 238
essex
thats miniwilliams that sells them..
Nick
Member #: 154
Midlands
or an old big end bearing works perfectly *wink*
I Suspected that it was him!
Old bigend eh? thats a good tip cheers!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
I use the mains as they fit better than a big end!
Alex
AlexF
got mine from halfords, as I'm flash with the cash, and spent a whoping £10!
Was it from your local Halfords, with the girl on the till with hairy gorilla arms?
They do a good line in Gromits there I hear....
thats the very one tom! if you liek hairy girls, get down there!
How is gromit doing?
He is fine, at the moment he is hanging from the inside of my garage door, he has just about recovered from his castle combe adventure now.
I use an old knackered 14mm socket.
Used the same one for years. Once it's in it seldom falls out.
I like the fact that several different soultions to this problem have been mentioned.
I wonder how many other ways people do this job.
Wil
nogin
Member #: 487
westbury, wiltshire
http://cgi.ebay.co.uk/AUSTIN-MINI-METRO-CL...1QQcmdZViewItem
here is one
"Can I legally marry people now that I am ordained in the Church of the SubGenius?" aka i know jack sh"t
i also make things
i love coming home to chrome
nogin
Member #: 487
westbury, wiltshire
oh just looked its the god damn same one doh
i also make things
Dangerous
Member #: 417
I thought you had one on your penknife *tongue*
nogin
Member #: 487
westbury, wiltshire
i dont have a pen knife just a spoon to wedge
i also make things
I always use the front engine mount off a metro. Wedges in there a treat!
Dangerous
Member #: 417
I was getting fed up with the screwdriver today,so drilled 2 holes in a strip of metal,then bolted between flywheel(where the straps are) and a wok cover bolt hole
Jobs a goodun
