| Home > General Chat > crank triggering | |||||||
28th Oct, 2005 at 12:00:23pm
Hello folks, On 28th Aug, 2011 Kean said:
28th Oct, 2005 at 12:18:49pm
could always give AlexF a shout, i believe he does the normal ones with the teeth machined into them. On 20th Oct, 2015 Tom Fenton said:
28th Oct, 2005 at 12:29:57pm
s crank makes it easier as it has some nice bolt holes to help you mount it |
28th Oct, 2005 at 01:01:26pm
well, the problem is, due to the belt drive, there's no room behind the pulley for the trig wheel unless I space the pulley and damper out about 1/4" even then I'll have to machine the disc face to fit proper.
28th Oct, 2005 at 01:24:20pm
What does an S damper look like? Fastest 998 mini in the world? 13.05 1/4 mile 106mph
28th Oct, 2005 at 01:28:30pm
Like this,
28th Oct, 2005 at 02:27:01pm
Would this fit
28th Oct, 2005 at 02:42:48pm
nope they only fit the non S damper, the minispeed one is the same as the KAD one too. On 28th Aug, 2011 Kean said:
28th Oct, 2005 at 03:52:30pm
Could it be modified to fit though?
28th Oct, 2005 at 05:03:50pm
the dish in the S damper is about half as deep and a larger diameter, plus there is 4 polts sticking up where the damper and pully attach. On 28th Aug, 2011 Kean said:
28th Oct, 2005 at 05:08:31pm
This is a cooper damper machined for 36-1.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
28th Oct, 2005 at 05:09:05pm
I'd say the 4 bolts make it much easier to go about mounting something than the normal pulley. If you can get hold of a blank undrilled trigger wheel, it would just be a case of drilling 4 holes on a PCD to match the damper bolts, then make 4 spacers sufficiently long to space the trigger wheel so it sits _just_ off the damper. Then bolt the lot up through your spacers and hey presto.......
612 Posts Member #: 414 Post Whore Dalbeattie Scotland |
28th Oct, 2005 at 05:36:04pm
Why not get a blank trigger disc and get it machined to fit the pully and weld it on the outside I did that with mine it was a dodle.
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
29th Oct, 2005 at 09:12:24am
just out of interest, has anyone concidered using a fluidic damper rather than using the old rubber ones or a cooper s one? Surely the've gotta be better, dunno if its worth the cost though? Was thinking about making up my own hub for it integrating a trigger wheel. I've seen the future and tbh its Pie
31st Oct, 2005 at 08:46:02am
Cheers for the input guys, I've got acces to a mill now so i'll macine them directly into the damper.
