Home > Help Needed / General Tech Chat > metro help
Ola
Member #: 683
Sweden
Hi !
I´m in my fiesta conversion brake job.. hunting for Metro drive flanges, have found a pair but i dont know if it´s correct.
They are from a 1989 Metro city. Hell.. i haven´t seen a Metro in real life *blush* , ( they didn´t export them to Sweden!)
Is the flanges from this car same as a Mg Metro or ?.
Cheers mates
Best regards from Ola
Dangerous
Member #: 417
Should be all metros after 88? were fitted with ap vented ,my 3 1990 ones are anyway
I think its all metros 84 on have vented discs.
Dangerous
Member #: 417
and mg's and turbo's from 82
Ola
Member #: 683
Sweden
Thank for all answers !!.
I have one more stupid question, is it same bolt circle as Mini(4 x101,6) on Metro 1989
Cheers again from Ola
pot_dan
Member #: 326
bradford, west yorks
hey a question i can answer!
yes! but you have to take the lugs off to fit (most?) mini wheels to them, i hack sawed mine off then finished with a grinder and hammerite. so the wheels fit on:)
HTH. Dan
http://turbominis.co.uk/car/105/
Ola yes, there the same
if you ae going to use the compleate!
metro swivle hub the pre 83 ball joints are the same taper size as the mini
but beware this gives a camber of positive camber of 1 deg and you have to use negative camber arms to correct this
the 4 pots make a nice cheap braking system off a metro
good luck!
pot_dan
Member #: 326
i think he is doing the fiesta conversion benross:) but you need to use the metro flanges i guess tho i have not looked into the conversion as i have 4 pots.
Dan
Richie
Member #: 628
i have done this conversion, i used new mini discs and had em turned down presto ! i used the MK1 fiesta callipers they have awesome stopping power i rate em above the S ones, and u can fit most 10" wheels over them *wink*
edit:- should mention that they were onto a j reg mayfair i didnt change the drive shafts etc
cheers
Richie
Edited by Richie on 8th Nov, 2005.
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
