| Home > Help Needed / General Tech Chat > carb spacer/gasket assembly order? | |||||||
1171 Posts Member #: 107 Post Whore Sunny Sussex |
5th Nov, 2005 at 10:07:46am
When fitting the carb to the manifold, whats the order of parts? As far as i can tell its the folowing but correct me if i'm wrong... Edited by Mike on 5th Nov, 2005.
5th Nov, 2005 at 10:11:34am
Sounds about right to me, you also need to sandwich the metal plate in there as well that supports the bottom of the heatshield/the throttle cable abuts to.
5th Nov, 2005 at 10:47:06am
ah y forgot that, does it go on the carb or manifold side of the spacer?
5th Nov, 2005 at 11:01:17am
Not a terribly clear picture, as I cut it from a larger one
5th Nov, 2005 at 12:42:10pm
However, by the look of it, I have got it manifold/gasket/spacer/gasket/metal plate/gasket/carb
5th Nov, 2005 at 12:48:16pm
cool, thx guys
