| Home > Technical Chat > Water-Methanol Injection | |||||||
193 Posts Member #: 510 Advanced Member Malta |
10th Nov, 2005 at 01:51:52pm
Hi all, I donated, but somehow didn't get the label! :( |
180 Posts Member #: 591 Advanced Member Rugeley, Midlands, England |
10th Nov, 2005 at 06:08:08pm
Hey i have also thought about this before and mentioned it on the website but was told its a cheats way out of solving the dreaded problem of pinking and you should address the problem the propper way.
11th Nov, 2005 at 08:30:01am
I'll look up my aero engines book again, and check the water/methanol ratio.
11th Nov, 2005 at 10:38:26am
well as one top turbo guru stated once!
11th Nov, 2005 at 12:17:20pm
water injection is one thing - water/methanol is another. Methanol is a fuel used in top-notch dragsters, and NASCAR IIRC. However, a fast-raod Mini cannot realistically be run only on methanol, but if it had to, there would be an incredible power hike to be enjoyed.
11th Nov, 2005 at 12:43:32pm
Methanol is a strange fuel. It is not as powerful as petrol, but it has the advantage of not detonating. To get the same power from an engine using methanol however, you have increase the compression ratio. So using methonal as a fuel on a forced induction motor you can run silly compression ratios (16:1 and above I think) with high boost and non of the detonation problems. I think this is why topfuel cars use it, I could be wrong.
http://www.twin-turbo.co.uk
11th Nov, 2005 at 05:01:26pm
your probly correct with the ratio, i read it in david vizards tuning the ford S.O.H.C book and i think its aimed for use on the track so the 75% water is going to be less harsh for road use. When building a engine to run on pure alcohol the fuel delivery system needs to be able to deliver 2.5 to 3 times as much fuel as the same engine designed to run on petrol, so dent expect very good mpg on a alcohol fueld car, lol, maybe a project for the future now that would be intresting. Another simpler idea is to add the alcohol to the base fuel as a octane booster, this will also help a engine run slightly cooler, generaly add 10% to your base fuel.
11th Nov, 2005 at 07:56:33pm
You did that in 10 minutes???
11th Nov, 2005 at 09:48:28pm
i'll say it again where do you keep all that info in your head pete! bloody good info though cant wait to see your car, glad to see your still alive |
12th Nov, 2005 at 10:20:08am
if you want bhp then just squirt lox in (thats liquid oxygen) no need for spark plugs then spend the next week looking for all you engine bits lol.
12th Nov, 2005 at 10:47:25am
I just remeber someone said that they ran a Mini engine on Methanol with a 2" SU, and needed floats on boths sides of the carb :) On 13th Jul, 2012 Ben H said:
14th Nov, 2005 at 06:55:52pm
Fuels..... confusing ay smelly clear liquids distilled from black sludge of dead animals trapped below the ground for millions of years. Unleaded comes in two main octane ratings in england 95 RON and 98 RON, correct???
