Home > Wanted > T3 Oil Return Pipe
Mike
Member #: 107
Sunny Sussex
as it says, i'm after the little hose and the plate that bolts to the block.
Any body got a spare for sale? :)
Mike
Member #: 107
Sunny Sussex
ok, i have a fuel pump blanking plate, can someone mod it for me?
Mike
Member #: 107
Sunny Sussex
*cought* BUMP! *cough*
The blanking plate needs a tube of approx 3/4" welding to it, and a hole boring through.
If you send me the plate and the tube I'll weld them together for you.
The pipe required is a 90 degree bend, again about 3/4" diameter. That is from memory though, you may want to check the outlet from your turbo before ordering a hose.
Mike
Member #: 107
Sunny Sussex
cool, any places off the top of your head as to where i get the hose?
Anywhere you like that sells samco type stuff. Plenty to choose from.
Just make sure its oil resistant (proper silicon is).
Mike
Member #: 107
Sunny Sussex
kk, i'll get the bits together and PM u
:: little britton voice :: i got one
Silicon actually decays when in contact with all but it will be fine for many years.
I spoke to samco a few years ago about making some proper ones that are floroulescant (that really doesnt look right!! *happy* but you get my point) lined that resists constant contact with oil.
Just use normal silicon though and inspect. it is 3/4" iirc.
I gave up with samco because i needed to have an order of £100+ and i didnt have the money at the time.
Maybe one day ill have the time and money to do more with the TM shop *smiley*
Mike
Member #: 107
Sunny Sussex
wolfie, pm sent :)
