| Home > Help Needed / General Tech Chat > Cam followers??? | |||||||
16th Nov, 2005 at 06:51:59pm
Right just been thinking, didn't hurt much. Best 1/4 mile 13.2 seconds @116 mph
16th Nov, 2005 at 07:47:38pm
there is i think to extra holes in the gallery which drsin down into the block from the followers.
16th Nov, 2005 at 09:20:12pm
A question, do you rigidly stick to the procedure of "knocking in" a new cam and/or followers at 3000rpm for 20mins?
16th Nov, 2005 at 09:57:35pm
Stock A+ cams (excluding the MPi ones) still look great after 60-80K miles. The ones i've seen of yours in thew past look like they've done 200+K miles.
Edited by turbodave16v on 16th Nov, 2005. On 17th Nov, 2014 Tom Fenton said:
16th Nov, 2005 at 10:39:16pm
Yes tom all done that, some times i do and some times i haven't.
Edited by Miniwilliams on 16th Nov, 2005. Best 1/4 mile 13.2 seconds @116 mph
16th Nov, 2005 at 10:44:08pm
I would say always knock the cam and followers in, I once saw a Pinto engine in an RS2000 eat a brand new expensive Shrick camshaft in about 5 mins from initial startup!!!!!!!!!
16th Nov, 2005 at 10:46:55pm
hell mate, but it doesn't seem to make any difference on my engine. Best 1/4 mile 13.2 seconds @116 mph
17th Nov, 2005 at 01:01:25am
Matt - you've tried everything; even highly expensive oil? Well, that says to me that you're overloading it. Plain and simple.
17th Nov, 2005 at 05:40:02am
yes his is TD i recon what you said is spot on as well as my self to much load on the lobes via 1.5 rockers, i think his springs are the same as mine which are the 180lb progressive minispares ones.
17th Nov, 2005 at 10:58:53am
Yes Dave i see your point all added to gether seems there is other issues.
17th Nov, 2005 at 11:13:49am
It's not just an issue of fitting "good" valve springs. What if you've got coil bind JUST before the valve reaches full lift? That will not make it run bad, but it'll put immense loadings on the cam/follower.
17th Nov, 2005 at 11:29:40am
LOL yes mine sounds like a tractor some times with the big gaps. Not a binding issue though i've checked many a time :( Best 1/4 mile 13.2 seconds @116 mph
about getting one drilled, i like the idea of running in on 1.25 rockers
