Home > Introduce Yourself > mini turbo
wylyeguy
Member #: 704
salisbury
hiya all,
Just joined and am in the process of rebuilding a 1988 round nose and modded for turbo lump.wonder what rad to use also which inter cooler would be a good bet and last but not least how the hell do you connect up from the turbo exhaust to exhaust system on a mini?regards dave.
Hello there.
For the radiator to use, most people use the Mini Spares super cool 2 core rad. This does the business!
As for intercooler, it comes down to personal choice. People use the following, Land Rover TD5, Escort RS Turbo, Sierra Cosworth, and many others. There is no hard and fast solution to the intercooler question, it is a case of making something to fit.
As for the exhaust system, Maniflow produce a large bore downpipe to suit. This then joins a performance system in roughly the same place as an LCB does, although you may find you need to shorten either the downpipe or the link pipe of your chosen system to suit.
T3Tone
Member #: 252
Sunny suffolk
hi and welcome
-MINI CLUBMAN 1380 TURBO-
hi and welcome
