Home > Technical Chat > turboing a a+1275
stevenford_uk
Member #: 144
can i do it?
i have got a turbo sitting at home, and a hif44 carb, can i just strap on a blower, fit the turbo oil feed, fuel pump and regulator, and a steel head gasket to the 1275 and expect it to work, or is there a lot more to it than that. i know i will have to cut the bulkhead out.
please help me. i need turbo power!!!!!
giallofly
Member #: 164
The Stig..
Newport Pagnell
you need to do your home work...
you will get all the info you need...
you need...
a decent bottom end & gearbox for starters
correct turbo fuel pump
correct rising rate fuel regulater
correct carb
modified fuel tank(DIY)
bulk head modifications
an aditional return fuel line to fuel tank
oil feed line.
various air and coolant pipes
exhaust down pipe
possibly to lower compression
cone or similar air filter.....i could go on, but that is the basics.
Have fun.
stevenford_uk
Member #: 144
but i need to know what everyone in the know thinks about it holding together if i put a steel head gasket on it, the bottom end is very good and the gear box is good.
i will want to run bout 8 psi boost.
giallofly
Member #: 164
The Stig..
Newport Pagnell
With 8 PSI a standard turbo type gasket will sufice, provided the head and block surfaces are flat and clean it will hold together.In my experienced opion a 8.5:1compression ratio is a good CR giving you the scope for a little more boost if needed. A turbo Must be set up correctly..run it lean and it WILL detonate and cause damage to pistons/head gasket etc.
i've run 14psi on a standard head gasket for short spells with no problems.
Top advice...don't listen to everyone's advice! stick to the experienced.
For a head gasket that most people i know use, (turbodave, jimster, etc) and thats the payen bk450. It really does the job and holds up to high boost. I think im correct in saying neither jim nor dave has had any failures. *happy*
giallofly
Member #: 164
The Stig..
Newport Pagnell
i agree with you.....i'm sure those dudes run high boost.
minimark
Member #: 19
newcastle
do you think they run more than 14psi ????
wow thats high!!!!!!!!!!!
all depends what you call high boost.
as Iain said, I run the BK450, with no problems
Wow look how we have all changed! New boys want 20psi now a days like it's the norm lol.
a great deal as indeed changed since the 'early days'. The biggest I can think of is affordable management
You have obviously never met Mark or else you would be able to detect the sarcasm in that post!
