Home > Ebay items For Sale > Here you go boys..............
giallofly
Member #: 164
The Stig..
Newport Pagnell
Go down to your local motor factors and ask for a Payen BK 450 for £10 or get one one of these for £19.50 posted!
ASK HIM SOME QUESTIONS!
JF.
link?
Dangerous
Member #: 417
http://cgi.ebay.co.uk/HEAD-GASKET-SET-ROVE...1QQcmdZViewItem
minimark
Member #: 19
newcastle
£6 in local mota factors .... robbing bastard
minimark
Member #: 19
newcastle
actually looking at it , you do get a few others gaskets within , the £6ones i use are only the gasket its self
Doesn't look like the 'biscuit brown' pukka exhaust manifold gasket though?
Does everyone use the bog standard "bog bore" gasket or the "metal ringed turbo" gasket? just curious, ones £2ish and the other £6ish each.
Just sorting an order for misc parts for my engine to get it running before crimbo
I use the pukka turbo one.
What Dave said
I've always used these all metal jobbies, and never had one blow. You can get a crappy one thats just a standard gasket with a metal covering on one side, but they're shite.
The last Mini show i went to there was a guy selling the proper ones for £2 each, me and Mike bought all he had between us. lol.
Phil. *smiley*
Nick
Member #: 154
Midlands
yup i use the proper ones aswell. usually just buy a full turbo head set from local machining place.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
which is the same as a MPi one... but the mpi one is cheaper :)
Alex
Damit! Pressed the edit instead of the quote button AGAIN!*angry*
Edited by turbodave16v on 22nd Nov, 2005.
AlexF
http://www.minispares.com/Product.aspx?pid=38056
aka this gasket? Is it big enough for ported heads though? mine has fairly large ports so didnt want to waste a load of money on the gasket that didnt fit *happy*
Not totally true AF!
http://www.minispares.com/Product.aspx?pid=37144
Is the Pukka turbo one - GUG704063MG
Is the 'injection' gasket - GUG704053MG
I suspect you got that information from MGRover? I couldn't understand it either, but they started supplying me these for a while, informing me that the 704063 was obselete and the 704053 was the replacement. I later found out that this statement was (for some reason) showing on the Parts database, but you could still purchase the 704063!
All very strange!
Dave, when you press "Edit" by mistake, just click "back" in your browser, then the post is not edited.........
well i ordered a injection one *happy*
its only really a temp measure to get me up and running so sure it will be fine for now. did fancy changing a load of £7ish ones left right and centre! not made of money *smiley*
finally got round to ordering virtually all the bits i need to get it running!!
This could be an interesting race, to see who can get theirs running first, you or me!
Probably be the only race my Mini will win!
Edited by Tom Fenton on 22nd Nov, 2005.
Yeah - that works fine, until you don't realise your mistake until after you've hit the 'post' button and wonder where your new post is, before a highly stupid feeling comes all over you as you look a few posts up and see you've edited someone else's post.
*laughing*
ha ha, dont doubt you'll be running before me tom, got lots of little bits to sort before mine runs!
erm ive been using an injection one this year
