Home > General Chat > Lights on warning
snowfruit
Member #: 557
Ireland
I m ust have run the battery down abot 5 times when my Mini was still on the road due to leaving the lights on accidentaly. Has anyone had any expirience fitting a lights on warning? Can on by taken from a modern car and adapted?
I think the Subaru system is the most sensible.
The lights are switched throiugh the ignition so there is no way you can leave them on.
If for any reason you did want to drain you battery for a few hours, there is a seperate switch to turn the sidelights only on with the ignition off..
Wil
snowfruit
Member #: 557
Ireland
Yeah thats the other way I had though of doing it... so wire the dipped and main beams throught the ignition. and the sidelights through a separate switch?
Dangerous
Member #: 417
They sell a little box in halfords,either that or wire a buzzer from maplins between live on the lights and earth on the door pin switch
clubman_dan
Member #: 142
Winchester
or just leave a note on the steering wheel reminding you to check the lights before you get out of the car *wink*
nutter driver
Member #: 47
Not very sunny swanage
next time your in a scrapyard, borrow a warning buzzer from a renault, (anyone car will do, but renaults hide them under the dash, passeger side.) tap into the sidelight feed, wire to buzzer, (theres about three pins iirc, just guess it, you cant damage it!!!) then another wire to the door switch. takes about ten minutes!
snowfruit
Member #: 557
Ireland
thanks nutter
Star Mag
Member #: 375
Leicestershire
ive done it before the way dangerous describes but it also buzzed when a passenger gets out!
Oh well, if you are Nic you'd probably like that, means no ladies can escape at night without you knowing!
Instead of a lights on buzzer, it could be a "passenger escaping in the dark" alert......
Dangerous
Member #: 417
Done it with a relay a external key switch and a horn before as a car alarm,didn't work to good though as when you shut the door it stopped*blush*
