| Home > General Chat > Running a mini on LPG | |||||||
4th Dec, 2005 at 03:06:05am
Hi, ive bought a 1.1 rover metro that runs on lpg, ive been told that it has a higher octane is that true? Someone has told me that when ive finished my mini if i set it up to run on lpg instead then i might be able to get more performance but use cheaper fuel? Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
612 Posts Member #: 414 Post Whore Dalbeattie Scotland |
4th Dec, 2005 at 09:05:34am
I am sure that you get around 20% less power from LPG but dont know about octane rating.I do a lot of miles and have always been interested in LPG but havnt seen enough info on it. |
4th Dec, 2005 at 09:16:27am
LPG needs to run a lot more ignition advance to produce optimum power. However, the majority of converted vehicles just use the standard ignition timing, and so do not make the most of the fuels capabilities.
4th Dec, 2005 at 09:52:09am
LPG has less power than petrol, even running more advance. It does have a higher octane though so doesn't detonate as easially. If you wanted to get performance out of it you really need to up the CR, which then screws you using petrol. As I understand it you can go full LPG, but it can be a bastard to start on cold days so you need some sort of heater.
http://www.twin-turbo.co.uk
4th Dec, 2005 at 01:12:35pm
What about with a turbo as in a mini? |
4th Dec, 2005 at 01:15:26pm
Theoretically I guess using LPG could be a way to get around the high standard compression ratio of the metro turbo engine, and still allow high boost to be used to get the power output.
4th Dec, 2005 at 01:22:45pm
Any info on Diy fit? |
4th Dec, 2005 at 02:04:32pm
Thats what im really interested in tom! Im definately going to do loads of research on it then. Im pretty sure my metro just runs same timing on lpg and petrol (its a k series). You have to drive for a minuet before switching to lpg aswell when its warmed up.
4th Dec, 2005 at 02:19:36pm
User Hedgemonkey and 1071 (peter) on here will no doubt have some good input - both seem to know a fair bit about scienciey stuff! On 17th Nov, 2014 Tom Fenton said:
583 Posts Member #: 233 Post Whore Beugen, Netherlands |
4th Dec, 2005 at 07:31:45pm
Running on LPG can be as good as running on petrol, even frezing cold starting should not be a problem. It all comes down to the health of your engine and the setup of your LPG installation, with a good setup there shall be limited difference.
18th Dec, 2005 at 01:02:12pm
I think the LPG conversion in my metro must be a really old one then, it was done in 2000 so must have been an early one.
18th Dec, 2005 at 01:18:48pm
LPG is really cheap, I did Birmingham to Rotherham in my old mans 3.9 v8 Range Rover, towing a trailer with my 205 on the back, on £13 of gas. My road car uses £13 normal fuel to do the same journey, not including the extra weight of the trailer and car.
18th Dec, 2005 at 07:31:44pm
A LPG installation from 2000 is not really old, could be a modular one. Hard to tell over the phone. 1970 that is an early type.
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
19th Dec, 2005 at 01:48:43pm
LPG in a mini is suicide ! i know a cheif fire officer that goes mental if you even mention the stuff lmao !
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
