Home > 998cc > What clutch
snowfruit
Member #: 557
Ireland
What type of clutch should I bee looking to replace the original item with given the following spec:
998cc at about 10 - 12psi (more if I feel courageous) with an intercooler. - not sure how much HP that might give.
Also I will be fitting solid front subframe mountings. Besides these are there any other engine fixings that should be upgraded added - e.g. ultimate engine steady, gearbox steady?
Edited by snowfruit on 6th Dec, 2005.
I'd go for a race/rally type plate with an orange or maybe grey spring. Non verto obviously.
snowfruit
Member #: 557
Ireland
Are there any other parts I'd need to replace in my clutch setup if I want to use the orange pre-verto clutch plate?
Without knowing whats in your car/engine at the moment I haven't got
(1) a clue
or
(2) a chance of answering you.....
snowfruit
Member #: 557
Ireland
Its a standard 998cc. nothing has been changed from standard engine wise
Edited by snowfruit on 7th Dec, 2005.
Still not enough info. Year? Clutch at the moment? A? A+? Verto? Non-Verto?
snowfruit
Member #: 557
Ireland
1989 Mini racing green - A+ pretty sure ... but I don't know what type of clutch is standard on these ...
1989 so therefore assuming standard engine, it will have a verto clutch.
So, you need to change-
Flywheel
Back Plate
Clutch Release Bearing
Clutch Release Arm and pushrod
Slave Cylinder location
Might be easier (initially) just to get a 'turbo' verto cover (loadsa guys here must have some spare ones) and a non-sprung centre...
On 07/12/2005 14:17:02 mini1071s said:
If there are any for sale cheap s/h after snow has his, i will have one :)
mmmmm .... I've just thrown a couple away of complete assemblys away, i'll check to see if there's any still lurking. You can have them for beer money if there is. *smiley*
Kean
Member #: 341
aka T2clubby
South Staffs
I have a complete turbo flywheel+ clutch assembly if anyone wants to part with some groats for it
snowfruit
Member #: 557
Ireland
Likewise whoever mini1071s doesn't get his from :)
snowfruit
Member #: 557
Ireland
This isn't the same thing is it... ? http://cgi.ebay.co.uk/mg-metro-clutch-kit_...1QQcmdZViewItem
