Home > General Chat > Which axle stands
snowfruit
Member #: 557
Ireland
pin and chain or positive ratchet? which are least likely to collpase on you or is there any difference?
Mini_Andy
Member #: 432
It dont really matter with a mini imo. before the ratchets came out the chain and pin worked fine.
i use both btw, buts thats because they were on offer lol
edit: the only difference is the hieght settings. my chain and pin has 3 settings, where-as the ratchet had about 8 i think
Edited by Mini_Andy on 9th Dec, 2005.
Ratchet types are far easier and quicker to use.
As both are perfectly safe, I'd buy the ratchet type.
Wil
nutter driver
Member #: 47
Not very sunny swanage
ratchet are a bit better imho. allow more of a fine tuning if the car is not on a perfect level for example, and are quicker to put up, take down when trying to fit them into a tight space....
Dangerous
Member #: 417
Can the rachet ones be turned around,as I normally use the pin ones putting the pin on the top instead of through the hole,so you can have the flat side of the base triangle level behind a car wheel,instead of the point ( for example )
