Home > General Chat > Castings
mini300bhp
Member #: 653
Cambs
What happend to all the tools for making blocks/heads etc. Cant someone get hold of these to make new ones?
Its only a bit of metal. If it blows it blows!
http://www.putfile.com/mini300bhp
no idea, not the sort of thing one hears about :(
I`ve often wondered about this...
What i will assume, is that the `head` casting moulds were modified to suit the slightly different MPi heads, and most likely the block moulds were destroyed, or butchered to suit the MPi...
It`d be nice to think that they`re sat waiting to be discovered in a foundry somewhere though!!!
BTW, is it difficult to have a new mould?`We do have a couple og heads/blocks to copy right? UK is FULL of foundries...
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
Id contact BMH
Then tend to get the cast offs
On a different note I read somewhere that many of the last gearboxes where procuded by JKD
Alex
grrr why cant I use full stops or apostraphys (SP)
AlexF
AV-R Technologies
Member #: 345
Guildford Surrey
Who knows where the moulds went. Probably destroyed. There would be no way anyone will re-do the blocks!! Most people think engines are to expensive as it is. God knows how much a new block would cost.
On another casting issue......If we were to get the turbo inlet manifold and plenum remade, what would you change?
http://www.avonbar.com
On the inlet, Id immediately get rid of the bottom of the runners that are infact lower than the head inlet. I think Ive got a brilliant drawing of this somewhere :)
andeh
Member #: 97
Near Daventry, midlands
would be facinating to find out where the castings went, particularly for the head. I have to agree on the block front, the amount of machining is imense although the thought of them getting rare or even the posability of casting it in ally :o
Personally the gearbox casting sounds the most interesting, since its been the weak point i'd love to redesign it. Infact thats something im working on at the mo.
The Aluminium Alloy A-series block has already been tried. Of course it didnt't work with three bearings etc..
I would change nothing on the inlet manifold - except for losing the water-cooling part - as Vegard described.
The plenum has a lot of scope - but mainly, change it completely - have the intake on the same side as the master cylinders.
A DV take-off is a given aswell.
Davem the inlet on the plenum IS on the same side as the master cylinders.
You do not agree with me on filling up the bottom of the inlet? I almost had this welded up last time it was off... This time it will ..
I'd be leaving the internal shape exactly as it is. My opinion only.
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
making a new plenum is not difficult... it certainly doesn't need to be a cast one!
If you take a design to someone good with a welder it shouldn't take them too much time!
Alex
AlexF
I'd agree with Dave on the shape of the inlet runners.
I have a few theories of my own on why the shape you mention is there, but not wanting to sound a cunt if my thoughts are wrong I am going to keep my gob shut for now.
No, please share.. The present shape might mean that the main inlet charge flow is situated in the middle of the head's port. Changing it to "my spec" will make the inlet charge run in the bottom of the head port... At least for the first few Cms... What do we prefer?
mini300bhp
Member #: 653
Cambs
Just out of intrest, is the alloy 12g940 head made using the same tooling?
nope...
mini300bhp
Member #: 653
Cambs
cheers
I know that at Aston Martin the jigs to make DB5,6 and some of the V8 jigs were used as hardcore under the foundations of the new crash repair shop. It could be that A series moulds suffered a similar fate somewhere.
Paul
