Home > Help Needed / General Tech Chat > standard head
Dicanio
Member #: 91
Hi
Can anyone tell me the standard volume of the turbo head chambers and the turbo piston dish.
Cheers in advance.
The head is 21.4cc, don't know about the pistons though, 6 or 7cc at a guess, someone will know.
wil
The standard Turbo pistons have a 12.5cc dish. I have measured two sets both from standard engines, and they were both this size. I was a little suprised at this so i measured my mates pistons as well and they're the same.
Phil. *smiley*
Phil is correct - 12cc or therabouts....
This is suggesting that the metros did have a lower CR than we all thought is it not?
D
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
hmmm
I might get the burette out tonight
this could change everything Dave!
alex
AlexF
Dicanio
Member #: 91
Thanks for the info guys, i supose i'm using this for stuff you guys have known for ages (I like to understand stuff). Using those fiqures i get a CR of 9.46:1. This sounds about right for a standard metty turbo, doesn't it??
Dicanio
Member #: 91
So if i increase chamber volume to 27cc (is this practical) then that should lower to CR to around 8.5:1. Is this a good CR to run higher boost
Don't forget to take into account the ring land, and piston flush height...
Dicanio
Member #: 91
Turbodave, took piston flush hieght (don't know what ring land is) also took the thickness of head gasket into account, used a web page that i picked up of Minifinity.com . It's http://www.wheelspin.net/calc/calc2.html
Edited by Dicanio on 19th Feb, 2004.
