| Home > Help Needed / General Tech Chat > fuel return pipe on 998 | |||||||
![]() 264 Posts Member #: 403 Senior Member sydney Australia |
15th Dec, 2005 at 02:33:12pm
g'day, maybe this should be in the 998 section but i'll give it a go here first, i'v got a 998turbo engine on the way and i'm planing on running all new breaklines and fuel lines, i'v already got the break lines and i was just wondering what size fuel lines to order (tank in boot to engine) i'v read the return line should be bigger but i dont know how big or if it differs between 998's and 1275's, any info appreciated. (been working 15-16 hours latley so might not reply for a while)
998 turbo |
15th Dec, 2005 at 02:38:49pm
The metro used a 1/4" feed, 5/16" return. This would probably be fine for your application.
15th Dec, 2005 at 03:02:46pm
I ran 5/16(8mm) feed and 1/4(6mm) return!!
15th Dec, 2005 at 04:07:21pm
The fact that at full chat out car does about 3mpg indicates that it does need fuel lines of the same order as a 1300..... http://www.twin-turbo.co.uk
15th Dec, 2005 at 04:12:07pm
mines the same as toms
17th Dec, 2005 at 11:14:10pm
ok, thanks, i think i'll go for the 6mm feed with the 8mm return but just out of curiosity, what is the advantage of using 8mm feed if you have to restrict it, wouldnt the 6mm do the job easier? (sorry if it's a stupid question)
998 turbo |
