| Home > Show Us Yours! > Ford Crank Sensor | |||||||
18th Dec, 2005 at 05:51:32pm
I have done a rough drawing of the Ford (EDIS) crank sensor for a friend of mine, thought it may be useful to some people so here it is.
18th Dec, 2005 at 05:52:22pm
Oh, copyright Spannerbitch-racing.
18th Dec, 2005 at 07:05:32pm
Great minds think alike. Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
18th Dec, 2005 at 07:59:11pm
Karl , you have way to much time on your hands mate....... |
18th Dec, 2005 at 10:06:10pm
How long before we see an A-series in its entirity drawn up in whatever system you're using then??? On 17th Nov, 2014 Tom Fenton said:
18th Dec, 2005 at 10:10:08pm
i'd guess at not very long!
19th Dec, 2005 at 12:54:54pm
Having kids has sure slowed things down for a while but i'm getting there.
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
19th Dec, 2005 at 01:10:27pm
can you do one which has been blown to bits ??? lol ! just out of question what does the crank sensor do ? i am gussing it warns of load / flex etc but am sure i am wrong.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
19th Dec, 2005 at 01:10:43pm
Fools seldom differ
19th Dec, 2005 at 02:59:52pm
Good work!!!
19th Dec, 2005 at 05:49:31pm
Dave it started out as an exercise to learn CAD (Solidworks 2005) but i find it kind of therapeutic.
19th Dec, 2005 at 07:01:39pm
After seeing your drawing yesterday afternoon I had a crack at learning how to use the 3-D bits of AutoCAD, in actual fact I didn't find it that hard, takes a bit more getting your head round but otherwise OK.
19th Dec, 2005 at 08:16:15pm
If you can do 2d... its only a small step to 3d.
AlexF |
![]() 264 Posts Member #: 403 Senior Member sydney Australia |
21st Dec, 2005 at 08:54:59am
um, while on the subject, has anyone draw'n the actual timeing wheel itself, i know how to use autocad and i hav a cnc mill at my dad's factory, i just cant get a hold of any dimentions for the timeing wheel (diameter of the wheel, length of the teeth, width of the teeth, size of the gap near the missing tooth ect.)
998 turbo |
21st Dec, 2005 at 10:05:53am
The only info you need to know is that you need 36 teeth, with one missing. On the wheel I have had machined I have made the teeth and the gap the same size, apart from that it can be pretty much whatever size you want, you will soon know if it works or not when you spin it up with a sensor looking at it.
60 Posts Member #: 629 Advanced Member Colchester |
22nd Dec, 2005 at 02:09:49pm
Does anyone have a recommendation to where I can get my crank pulley/damper milled with the 32 trigger notches for the sensor? |
22nd Dec, 2005 at 10:55:46pm
Try McGyver....
30th Dec, 2005 at 07:49:31pm
Thanks TurboDave, I'll pm Tom |
31st Dec, 2005 at 01:44:54am
teeth and gaps do not have to be the same size. long as all the teeth are the same size, and gaps the same size your alright. and you want (ideally ) 36 "teeth" includign the "missing tooth" hence the notation 36 "minus" 1 (36-1) as 36-1 is generally used for the ford edis stuff, incase you go down this route. it also makes workign out trigger angles easier in your head :) turbo 16v k-series 11.9@118.9 :)
