| Home > Help Needed / General Tech Chat > Compression ratios | |||||||
20th Dec, 2005 at 04:29:37pm
Helloo, was just wandering, could anyone tell me the standard compression ratio of a metro turbo engine?
20th Dec, 2005 at 04:45:38pm
Standard compression ratio is 9.4:1
20th Dec, 2005 at 04:52:20pm
Any ideas of CR i should aim for on that setup?
![]() 928 Posts Member #: 326 Post Whore bradford, west yorks |
20th Dec, 2005 at 05:43:48pm
the avonbar phase 2 is tried and tested on here and comes back as a good cam, i have been in benrosses car with this cam and it seems verry good, not a bad idle and it pulls like a train.
20th Dec, 2005 at 05:48:22pm
It is a bit of a balancing match, if you want to run big boost pressure e.g. up to 20psi, then you want to aiming around the 8.0:1 mark. However, it is only worth going down this low on compression if your pistons will withstand that kind of boost pressure.............
20th Dec, 2005 at 10:18:36pm
Ritey, thanks for the info! Well im palnning to re-bore so will be getting bigger pistons and they will be able to handle the job i should think. Cheers for the tip on the cam!
20th Dec, 2005 at 10:23:11pm
12 minium but csan be increased with a bleed valve
20th Dec, 2005 at 10:26:48pm
You may be able to lower the 12psi by lengthening the actuator rod to decrease the preload.
21st Dec, 2005 at 09:38:24am
the 276 does work on a 1380 turbo but cant coment on a 1293, but does come with the lumpy tickover as per usal, the phase 2 seems to be the top cam on most peoples choice.
21st Dec, 2005 at 12:24:44pm
Thanks for the info guys, much appreciated! Ive realised actuators are quite expensive! So may be wanting to stick to the 12 i have now, ill keep what you said in mind tom :).
21st Dec, 2005 at 12:35:50pm
Straight cut drops
21st Dec, 2005 at 02:31:55pm
A friend of mine {Mike} ran a 1275 Turbo motor with a 276 cam, T2, intercooler and 10psi boost. The engine made 132 bananas {hp} and was a great little motor. Idle was slightly lumpy but it pulled well enough, drivability may not have been as good had a T3 been fitted .....
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
21st Dec, 2005 at 03:39:52pm
On 21/12/2005 12:35:50 Tom Fenton said:
Straight cut drops Cross pin diff The standard items will not put up with 12psi for long! ARP rod bolts are always a good idea on any engine build in my opinion. couldnt agree more with tom, for £60 quid you can get a full set of ARP rod bolts out of the mini mag, and u have that lil bit more reasurance.....for 7 quid extra you could get the uprated main strap (not mandatory but every lil bit to reinforce the bottom end helps) you would need to get your main strap machined (about a fiver) just make sure prior to build that you have had your crank Mic`d and ground (if it needs it) dont rush the build or you will be sorry :) and of course at every stage ask loads of questions like moi.....i am sure i have irritated peeps here but they always help. to summerise imho the bottom end is the week link ie big ends, drop gears and diff theses are where iam spending the spondules, everything else can be modded as time goes by and more bananas are wanted. Richie Edited by Richie on 21st Dec, 2005.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
22nd Dec, 2005 at 07:12:01am
On 20/12/2005 16:29:37 Rich1275 said:
Helloo, was just wandering, could anyone tell me the standard compression ratio of a metro turbo engine? Cheers, rich How could you write this if you were out wandering? Palm? On 13th Jul, 2012 Ben H said:
22nd Dec, 2005 at 10:37:32am
The standard items will not put up with 12psi for long! opinion. Is there much difference between say 10psi and 12psi then? If i was to run 10psi on a standardish 1275 turbo engine would they be up to the job? So i need to build my bottom end and gbox like a tank do i? Sounds logical to me:cool: Keep the info comin' hehe |
22nd Dec, 2005 at 10:49:44am
If I were building an engine and wanting to do it on a budget, I would get the gearbox and bottom end done first as a priority. Cross pin diff and straight cut drops make a good strong gearbox, straight cut gears as well if you can afford them. Then moving upwards, centre main strap, ARP rod bolts, good quality pistons, Avonbar Phase 2 camshaft.
22nd Dec, 2005 at 11:19:23am
I thought ARP rod bolts/nuts were only required if you are planning on revving the engine hard (7500rpm+)!!! Or is this just for piece of mind? -MINI CLUBMAN 1380 TURBO- |
22nd Dec, 2005 at 11:22:02am
For me, piece of mind, and also as an "insurance" policy, we all know the damage a failed rod bolt can do to a normal engine, let alone a mini with its gearbox is close proximity! Having spent a considerable amount of time money and effort on building a straight cut gearbox, an extra £60-odd for a set of ARP rod bolts does not seem too bad!
22nd Dec, 2005 at 11:26:34am
i shoud know about the weakness of a standard box with starship miles on !
22nd Dec, 2005 at 11:26:42am
Yes fair point -MINI CLUBMAN 1380 TURBO- |
22nd Dec, 2005 at 03:33:36pm
Wiked! Thanks for that! I think its a good idea actually, getting the box and bottom end up together and just ipgradeing the rest once its bedded in!
Edited by richminiturbo. on 22nd Dec, 2005. |
22nd Dec, 2005 at 03:48:07pm
On 20/12/2005 22:23:11 Nic said:
12 minium but csan be increased with a bleed valve although my 10psi seems to be about 8, avonbar may be able to supply you with a lower rated spring You need to set up your actuator... think pre-load! Alex AlexF |
