| Home > Help Needed / General Tech Chat > rockers | |||||||
66 Posts Member #: 775 Advanced Member stourport-on-severn, worcestershire |
20th Dec, 2005 at 09:34:32pm
would it do the same job if i left the standard metro turbo cam in and put 1.5:1 or 1.7:1 rocker in, compared to putting a phase 2 cam in and left the 1.3:1 standard rockers.
If in Doubt, go flat out !!! |
20th Dec, 2005 at 09:44:17pm
It has alot to do with cam timing and duration not just all out lift....
20th Dec, 2005 at 10:28:08pm
give it a go like john says but.....
20th Dec, 2005 at 10:32:47pm
that has made up my mind in going for a phase 2 cam.has any body tried the phase 2 cam with 1.5:1 rockers and what about the phase 3 cam any good? If in Doubt, go flat out !!! |
20th Dec, 2005 at 10:35:35pm
Use the phase 2 with 1.3 rockers you will not be disappointed................
21st Dec, 2005 at 09:35:39am
the phase 3 is a touch to radical and power losses of 30 hp have been seen on some high boost engines.
21st Dec, 2005 at 02:42:23pm
I've tried 1.5 rockers on a standard cam, 1.5 rockers on a P2 and 1.5 rockers on a P3.
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
21st Dec, 2005 at 03:29:25pm
avonbar recomend with the phase 2 two use 1:3 ratio rockers... imho i would save and get full roller rockers, as apposed to the roller tip as they are stronger and the bushes are replaced with bearings
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
21st Dec, 2005 at 06:14:19pm
Yes funny enough i did think about getting some 1.7 rockers, but the wear on mine now is bad enough so that put me off. Best 1/4 mile 13.2 seconds @116 mph
29th Dec, 2005 at 11:51:16am
The wear on your what?
I seriously doubt it! |
Forum Mod 1140 Posts Member #: 93 Post Whore Near Lincoln |
29th Dec, 2005 at 11:53:16am
On 29/12/2005 11:51:16 paul wiginton said:
The wear on your what? valve guides wear more due to increased speed in which the valve opens and closes that the higher ratio rockers give |
29th Dec, 2005 at 01:28:45pm
MFT, the problem with full RR is that if a bearing fails then it changes drastically, if a normal plain bearing fails then it goes gradually over time and easier to correct...
29th Dec, 2005 at 02:41:14pm
My rockers are plain bushed shaft with roller tips also........
29th Dec, 2005 at 04:46:19pm
i can see you holding the spanners now tom
29th Dec, 2005 at 04:47:19pm
We'll see...........
29th Dec, 2005 at 05:13:04pm
plus they will wear out the cam lobes and followers bloody damn quick if you aint carefull always looking for them bigger bunches of bannanas |
29th Dec, 2005 at 05:41:30pm
On 29/12/2005 17:13:04 turbo hogster said:
plus they will wear out the cam lobes and followers bloody damn quick if you aint carefull Only if you don't change valve spring pressure to suit... This is not a mechanical fault, it's a builder/user fault.. If you change the rockers form 1,3 to 1,5, you need to lessen the valve spring pressure, If not, you might experience excessive wear. On 13th Jul, 2012 Ben H said:
29th Dec, 2005 at 10:54:06pm
Odd, I have 310 scatter cam and I shimmed springs to up the pressure. This is why I run x-drilled billet cams. Only worn out 1 in 6 years which was a 296 Kent, their hardening aint as good as Piper so they made my 310
1st Jan, 2006 at 10:55:00am
iain here what u r saying mate, but my scource was saying that the gradual wear puts offset loads onto the valves... with full roller rockers the load is distributed properly therefore the load is evenly placed on the main bearings with extends life of the bearing....i take your point on board, but i have seen half roller tip failures, but am yet to see a full roller rocker setup failure....touch wood....all engines have been full race and not road use. so have been super abused each to mtheir own, but i will be using full roller rockers
