Home > Help Needed / General Tech Chat > Rod or Remote gearbox
barkiboi
Member #: 591
Rugeley, Midlands, England
Hey all,
Liking the new site, well posh.
Got a free 1300 engine, from the engine number think its a S engine. I am thinking of overhauling and tuning it, keeping it N/A to fit into my marcos.
I think the engine is fitted with a remote gearbox, what are the differences between the rod and remote gearboxes both visibly and strength, i belive the later rod boxes are better is this true, if my 1300 engine is fitted with a remote box could i swap to a rod change box if they are better and would it just be a case of bolting on a rod change box to the engine.
Any help would be of great help many thanks
Barkiboi
a.k.a Chris Barkas.
If the gearbox is 4sync, there is NO difference between that and a rod box. I like Remote boxes, but there are fewer parts that wear in the linkage system on the rod ones. Strengthwise, they're all the same! ( Apart from 3 sync which are inferior)
Richie
Member #: 628
the rods are longer than the remote, but the remote is a better box if you are rallying / rally x as the linkages are inside the armoured cast remote *wink* i have seen many cars rolling off the track with snapped linkages. i personally thought the remote box was a stronger box but have no evidence to substantiate this, other than 5 seasons rally x nothing technical though
Richie
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
All gears inside bar the reverse idler are the same, so they EXACTLY the same :)
Richie
Member #: 628
vegard not sure if you are replying to my comment, but if you are i was refering to the rod change as aposed to the remote change, if you measure them off the box the remote changer is slightly shorter than the rod changer
Richie
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
andeh
Member #: 97
Near Daventry, midlands
someone posted a very good point about the remote box in that its basically the ultimate ultimate engine steady. However, i can see that a car with shot engine mounts would probably duff the diff cover and changer, probably why there are so many of those gearboxes with cracks in them
Richie
I was thinking about the internal gears. The linkage rod(s) might be longer, you tell me :)
Yes, the remote acts as a giant engine steady...Good idea isn't it...
Richie
Member #: 628
lol i am clear on what ya mean now vegard... i can confirm through using both that the linkages are different lengths the remote type being slightly shorter.
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
barkiboi
Member #: 591
Cheers for that clears up a little bit i think, was thinking about having the gear linkage within the car (like most severns and miglias) as i under stand it speeds up gear changes, is this true?? also if i was to do this would i need a rod change box apposed to my remote change box.
Any ideas.
Barkiboi
a.k.a Chris Barkas
It does not at all increase the speed of shifting, but it allows you to cut the lever, move the lever to wherever you want it to be, and increase room for exhaust etc.
Yes, you'll need a rod-box for this.
