| Home > Help Needed / General Tech Chat > 850cc Piston Query | |||||||
27th Dec, 2005 at 09:38:27pm
I helped a friend from my mini club pull apart his 1965mini 850cc engine as for rebuild.
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
28th Dec, 2005 at 12:55:12pm
pistons are a problem in 850's. There are a few sets still going around, but they arnt generally for sale anymore. Last time i checked DSN still had some for sale on their site, but this was a while back and i dont know the source of them. I wish minispares would release a 'mega' version of them.
28th Dec, 2005 at 12:58:24pm
IIRC, the '1071' chap (sorry cant remember his name) has his fingers in a few pies in the 850 front, maybe he knows more. I've seen the future and tbh its Pie
28th Dec, 2005 at 01:15:26pm
http://www.jp.com.au/JPPistons.html I've seen the future and tbh its Pie
28th Dec, 2005 at 01:22:59pm
The 998 piston idea sounds like a good plan. Would the standard a+ 998 con rods be suitable, or would a swap need to be made to the old 850 rods |
28th Dec, 2005 at 04:50:27pm
you need rods to suit the pistons, im not sure if there were any press fit 850 rods? If you get the press fit hepolite pistons from minispares then the later rods from a+ engines would be fine. AFAIK, i might be wrong however, there is no such thing as a 998 A+ rod, i belive they were the same as the earlier press fit piston'd engines? Whatever they are they'd be ideal, i have some for my own 850 engine (also fitting 998 pistons, but will be using an a+ 998 block aswell).
28th Dec, 2005 at 06:37:38pm
I'd watch Ebay. They do pop up occasionally..
