Home > General Chat > su carb pic
TURBO ME
Member #: 772
new york
i've been looking for 2 hours i saw it before looking for pic of complete carb kit need to compare with other to see if it's complete rebuild kit or not. does anyone know where it is thanks
Dangerous
Member #: 417
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=2878
Dangerous
Member #: 417
http://www.minispares.com/Product.aspx?pid=36133
http://home.online.no/~lyngset/index.cfm
21/09/2005 10:45:21 PM User | Quote
It's similar but you get that lot and more. Thats the service kit whereas the one i sell is the rebuild kit.
It includes shaft, bearings and plain butterfly so makes a proper job of it. Its all easy enough to do as can be seen with these instructions.
I've sent you a PM regarding price inc postage etc.
TURBO ME
Member #: 772
new york
those i found i'm looking for the pic with the box in the background and the parts all laid out in front i think it was a pic of the one that iain sells
The post above describes what etc you get *smiley*
basically the bearings, shaft and a plain butterfly (esential if using a DV)
but for maybe £5 etc (when thinking of p&p etc with MS) then the choice is yours.
its dead easy to fit the bearings despite what you may have been told.
Bearings (bushes, correctly) are dead easy. As long as you have a vice and either a selection of small 1/4" drive sockets, or access to a lathe to make a press tool, they push in and out no problem.
