Home > Help Needed / General Tech Chat > inlet manifold ?????
turbomini78
Member #: 492
I am running a 1380 turbo w/ 8psi. I currently do not have a dump valve insatlled and would like to do so. I have a modified plenum. The question I have is at the moment the inlet manifold has the adapter but the servo is linked to it. The top of the adapter has a two prong plug. Any input on how I go about installing the dump valve?
jimmy
Member #: 829
essex
if the dump valve is fitted to the plenum you need to call avonbar/minispares for the maniford spacer with the vacuum pipe in it at the top of it if you call minispares the part number is MFA446 or make one your self good luck
1293 Turbo mini
slim_shadyuk
Member #: 703
Plymouth, On the floating skip known as HMS Albion
Is there not another take off pipe on the manifold you can connect it to?
Have you considered drilling and tapping to fit a small vacuum pipe?
Whats going to break next!?
Turbominis Worst Advice winner 2006, get in
Nick
Member #: 154
Midlands
i thought thats how most people did it anyway? i've got 2 nipples put on my inlet. one for the boost gauge and one for the dump valve trigger.
Careful Bud you will get Nic overexcited........
do you think you should see a doctor?
very good tom
