| Home > A-Series EFI / Injection > SPI Injection Pressure | |||||||
14th Jan, 2006 at 04:41:50pm
I've managed to gety hold of a SPI tank with integral pump for my injection system.
14th Jan, 2006 at 05:21:52pm
Spi is 2-bar max i understand. The pump delivers an amount plentiful for a Carb'd A-series turbo - But It'll struggle to work 3-bar rails, espeially when you start adding boost and raising the pressure. On 17th Nov, 2014 Tom Fenton said:
14th Jan, 2006 at 05:37:41pm
So if i'm using the SPI tank and 2 MPI injectors, I need a 2 bar pressure regulator - any ideas?
14th Jan, 2006 at 07:55:33pm
Personally - I'd avoid the SPi pump. MPi units are out there - Sell what you've got and get one of these. On 17th Nov, 2014 Tom Fenton said:
63 Posts Member #: 834 Advanced Member Falmouth, Cornwall |
17th Jan, 2006 at 03:34:03pm
On 14/01/2006 19:55:33 TurboDave said:
Personally - I'd avoid the SPi pump. MPi units are out there - Sell what you've got and get one of these. How do you tell the difference? I bought a couple of minisport's injection tanks complete with pumps and assumed they were MPi....I had better check before I melt something :) Peter
17th Jan, 2006 at 03:46:27pm
There is a difference...
46 Posts Member #: 733 Member Gatwick |
19th Jan, 2006 at 11:18:44am
Yeah dave is right bin the SPI tank it runs 2bar vmax the MPI is the one to go for, I have just taken delivery of a 13000 miller, the MPi should run 3 bar but still may not be ok on boost, but you can fit a higher pressure pump in the mini tank.
23rd Feb, 2006 at 08:43:11pm
OK guys,
23rd Feb, 2006 at 09:00:29pm
Good to know Nigel...
23rd Mar, 2006 at 09:42:57pm
SPI rail pressure is 1bar as stated in the Rover workshop manual On 26th Oct, 2004 TurboDave16v said:
146 Posts Member #: 350 Turboing minis since '89<br> Supercharging minis since '04 |
30th Mar, 2006 at 12:53:24pm
the spi pump is too low delivery and pressure , with my supercharger /M3d setups the mpi pump will supply enough fuel for about 135 bhp max , after this i use a replacement in tank pump rated at 300 bhp , its smaller than the mpi or spi unit and costs £90 inc with wiring and new bag filter |
30th Mar, 2006 at 03:27:37pm
So presumably just cut of the SPi pump and fix the high pressure one. I will try and find some compression type fitting to hold it all together.
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
14th Apr, 2006 at 10:31:29am
just out of interest, anyone know how much fuel an spi tank is good for? I've seen the future and tbh its Pie
14th Apr, 2006 at 04:41:13pm
7.5 english gallons - just like any late-70's (ish) on tank. On 17th Nov, 2014 Tom Fenton said:
14th Apr, 2006 at 05:15:47pm
Yes, all post 76 tanks are 7.5 gall, the earlier ones are 5.5 gall.
14th Apr, 2006 at 11:48:57pm
Here is a test I ran on my SPi to find out ho far the car would run with a full to the brim tank and for how long after the needle stopped reading at the bottom of the red
15th Apr, 2006 at 03:39:22pm
oops, i meant a rough guide to how much fuel it can dish out/bhp's worth, not how much it holds. Edited by andeh on 15th Apr, 2006. I've seen the future and tbh its Pie
15th Apr, 2006 at 03:48:05pm
