Home > General Chat > Wiper Motor Options?
SumpNut
Member #: 28
With the firewall having been removed from my car and a bulkhead box fitted my origional mounting points for the wiper motor are gone.
Its not too much troble to get something made up - however I was wondering if there are better wiper units availble - possibly aftermarket light weight units?
If anyone knows I'd appriciate it!*happy*
Thanks
Dan
A trick on the old rally cars was to move the motor inside the car. The tube that carries the rack can be bent to allow you to place the wiper motor wherever you desire!
However as you say, the standard items are usually quite poor, a trick that helps often is to make sure the wheelboxes are properly lubricated, as these can dry out and go stiff over time.
Richie
Member #: 628
i used to use a fiat panda one on mine, it mounts snuggly under the scuttle...quite powerfull too, never stalled when tonnes of mud etc was thrown onto the screen...worth a look :) should also mention they are light, modern, cheap and petit !
Richie
Edited by Richie on 16th Jan, 2006.
TRADER HALL OF FAME
TRADERS OF SHAME
1 user....pm me 4 details
LEGENDS
MikeRace, Mini13
On 17th Aug, 2009 Jay#2 said:
SumpNut
Member #: 28
Cheers MFT, Sounds like a plan - what fittings are on it for wipers, could I stick with the standard mini arms and blades?
Dan
dan
Member #: 93
i've got rear metro wiper motor for mine, like mft it should mounts straight under the scuttle, not sure if its off mk2 or mk3 metro though
Richie
Member #: 628
i believe with the arm needs to be cut down, but i would need to remind myself
TRADER HALL OF FAME
TRADERS OF SHAME
LEGENDS
MikeRace, Mini13
