Home > Help Needed / General Tech Chat > right then ppl...
smurf
Member #: 627
Welsh and sexy, what more do you want?
cwmbran - south wales
i need to settle an argument so...what would i need to change to put bigger wheels on my mini...
its currently running 10s on drums....
Edited by smurf on 17th Jan, 2006.
for 12's nothing.
for 13's you might need to cut the arches back a bit.
smurf
Member #: 627
On 17/01/2006 12:38:07 AlexB said:
for 12's nothing.
think yr right there....
current clearance..
yes, but you'll change the tyre size too, so that difference might not actually change
richminiturbo.
Member #: 719
Horndean - Near Portsmouth
7x13's you have to cut about an inch all the way round the radius of the actual panel for clearance, not of radius of wheel but because of width on turn!
smurf
Member #: 627
On 17/01/2006 16:50:52 mini1071s said:
yes, but dont! Stick to 10's. They just work better on a road car. 12s destroy your ride quality. 13's may be OK for the track, but on the road they are awful and make your car slower.
Save up to put discs on instead and keep 10's.
hehe that was the answer i was lookin for!
someone told me (who drives a chavved up passat) that i should put bigger wheels on it cos it looks like its driving round on 4 donuts....*evil*
andeh
Member #: 97
Near Daventry, midlands
if he drives a modded passat hes not someone to be listening too.
10's are the best, easiest, cheapest solution to getting the best from your car.
13's do work but require more money to get them working aswell as 10's on a std car.
Nicky
Member #: 333
Tadley, Hampshire
Passats rock
However, mini's look best on tens *happy*
Carl
Member #: 95
liverpool-on-sea
id say if you go to bigger wheels itd be a very good idea to fit discs as well.
i wen from 13 to 10s but its down o personal choice realy*smiley*
