| Home > General Chat > helicopter gear linkage joints | |||||||
18th Jan, 2006 at 03:26:40pm
first of all is there anyone on here can get these for considerably less than the usual suspects,
18th Jan, 2006 at 07:01:20pm
One thing i thought of using but have never got round to looking at is the "ball and socket" type impact UJ's.
969 Posts Member #: 47 Post Whore Not very sunny swanage |
18th Jan, 2006 at 08:10:03pm
i know people always say that these things are bloody expensive, and i have heard of people trying to use socket ujs before (not impact ones mind) and these failing really quickly....
And on the 7th day........... God created turbochargers! |
18th Jan, 2006 at 08:50:01pm
Carl i've used these at work and they seem robust enough for motor shafts.
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. |
18th Jan, 2006 at 08:50:18pm
yeah i heard about the normal uj's failing hence thinking of the impact versions. Havent got round to getting one though! |
18th Jan, 2006 at 08:54:12pm
Not a bad idea pete on the steering u/j's, the only thing that comes to mind is that you would have to see if they are capable of taking axial pull/push loads? As in a steering application, they are supported, and only transmit a radial load.
31 Posts Member #: 478 Member Ooop Norf (Cumbria) |
18th Jan, 2006 at 09:00:23pm
The easiest source of cheap UJ's (for steering and gear linkages) is a Mk4/5 Escort. They are plentiful in scrapyards and have two in the steering column. Should cost you about a fiver. Clubbyestate : Brown and loud - fast soon ! |
![]() 282 Posts Member #: 616 Senior Member Birmingham |
18th Jan, 2006 at 09:09:30pm
That website is called lovejoy-inc.com do you think he's diversified? |
18th Jan, 2006 at 10:23:07pm
fair point there tom.... not something i'd overly considered..... could well end up with the same problem as socket ujs then... plenty strong enough round and round, but as soon as you start to apply axial loads, kinda shit themselves and fall apart.....
19th Jan, 2006 at 09:21:12pm
no but i have found a source for percision uj@s , that with a modificatiob will ft the mini box outpput shaft,
19th Jan, 2006 at 10:20:40pm
Sounds good |
27th Oct, 2007 at 07:55:44am
On 18th of Jan, 2006 at 08:50pm iain said:
yeah i heard about the normal uj's failing hence thinking of the impact versions. Havent got round to getting one though! ![]() Did you go for the impact UJs in the end? and if so how have they faired? Isambard Kingdom Brunel said:
![]() 370 Posts Member #: 181 Senior Member Chard, Somerset |
27th Oct, 2007 at 09:04:33am
I got some from R.S. Components. They're about £17 each and come with gaitors. Also come as a blank so you have to drill the holes in the end to suit the diameter rod you're using. Go to rs.com, check under the yellow section, then mechanical components, then universal joints.
27th Oct, 2007 at 11:32:18am
which brand did you buy? how does the quality feel? is it nice an tight? |
