Home > Help Needed / General Tech Chat > Oil pressure drops when i put the clutch in
diddy
Member #: 505
Stockton-on-Tees
As the title says,
oil pressure is 65 ish when cold idle'ing, 30 ish when warm idle'ing, and 50 ish when warm cruising.
When i put my foot on the clutch the oil pressure drops right off to the point that the oil warning light comes on.
It's been suggested that the crank endfloat could be incorrect,
any suggestions?
Nick
Member #: 154
Midlands
do the rev's drop off aswell when you clutch in?
doesn't sound good either way dude *indifferent*
diddy
Member #: 505
Stockton-on-Tees
No revs stay constant
Skinns46
Member #: 165
Cambridge
Yeh Probably is end float related. If you've got a heavy clutch they wear out the thrusts in time. If you sit at the lights with your clutch down that doasn't help either.
Check the end float!
http://photobucket.com/albums/y139/Skinns46/
Listen carefully, if you have rev counter look at that
i bet the revs drop.
andeh
Member #: 97
Near Daventry, midlands
i agree, i cant see any other reason for the oil pressure to drop when the clutch is in, unless its creating more bearing clearance somehow :-
diddy
Member #: 505
Stockton-on-Tees
Can't check the car till tomorrow, but what does it mean if the revs do drop?
Fucked thrusts!
diddy
Member #: 505
Stockton-on-Tees
Oh dear!!
Best have a look at that tommorrow.
Cheers for the replies, i'll let you know tommorro
Dave
Dave, should I put the pictures up?? *wink*
diddy
Member #: 505
Stockton-on-Tees
Pictures??
Pictues please!
diddy
Member #: 505
Stockton-on-Tees
Wha would you like to see pictures of ?
AllanMcD
Member #: 414
Dalbeattie Scotland
If you have a sister show us I picture of her*tongue*
http://www.rabdunn.co.uk/
miniminor63
Member #: 672
The oversills police
Oslo, Norway
maybe a bit OT but I had the revs drop when clutching this autumn. That was NOT the thrusts, but one of the bushes in the primary letting go...
Dangerous
Member #: 417
Nick
Member #: 154
Midlands
those are my fucked thrusts!
looks like dangerous beat you this time vegard *tongue*
Crap :)
The next engine, I will build with lots of crankshaft endfloat just to get the most properfecked thrusts of all *wink*
Edited by Vegard on 22nd Jan, 2006.
Dangerous
Member #: 417
What like these
dangerous thrusts are the worst!
sorry vegard
jimmy
Member #: 829
essex
it`s a good trick dangerous done on the computer
1293 Turbo mini
diddy
Member #: 505
Stockton-on-Tees
Hope my thrusts aren't that bad.
The engines only done 1500 miles
Nick
Member #: 154
Midlands
those thrusts in the pic dangerous posted had only done 500 miles *wink*
i was having issues with my clutch pedal though, it was fucked and wasn't returning fully so putting constant pressure on the crank :(
diddy
Member #: 505
Stockton-on-Tees
Exams are finally over, so i've had time to pull the motor.
These are the thrustwashers
Crank endfloat was 2 thou
Need to replace the main bearing shells as the centre one shows quite some wear, also need a rubber ring for the belt drive kit as it had snapped and lodged up near the crank pulley
