| Home > Help Needed / General Tech Chat > should i rebuild? | |||||||
125 Posts Member #: 751 Advanced Member Aberdeen |
26th Jan, 2006 at 01:17:26am
Ive just bought a metro turbo engin eto go in my mini once its restored. I was told the engine ran fine when removed from car but would i be best rebuilding it just to be on the safe side?
26th Jan, 2006 at 08:59:28am
i'd go for a full rebuild/rebore personally. have a look at http://www.morspeed.co.uk for one of his 1293 engine kits if you want to build it yourself and save a bit of £££... if you plan on raising the boost then its the only way forward imo... Edited by Nick on 26th Jan, 2006. On 20th Oct, 2015 Tom Fenton said:
26th Jan, 2006 at 10:53:10am
yeah i was thinking i might need a rebore but im on a bit of a budget and dont want to spend thousands on the engine. Is it possible to get a rebore and just use bigger piston rings and keep the origional pistons or am i talking rubbish?
26th Jan, 2006 at 11:12:00am
No you can't bore it and just use bigger rings, that will not work, as you will get piston slap.
26th Jan, 2006 at 01:09:53pm
My first ever turbo engine didn't need a rebore - I just replaced the shells, oil pump, valve seals, etc,etc, etc and it lasted well.
Edited by turbodave16v on 26th Jan, 2006. On 17th Nov, 2014 Tom Fenton said:
26th Jan, 2006 at 08:50:21pm
Can i do a compression test if the engine isnt installed in a car and running?
![]() 3184 Posts Member #: 628 Post Whore a LIL fishing village on the coast - Newcastle Upon Tyne |
28th Jan, 2006 at 11:06:11pm
if it was moi, and it has been, i would go for a full rebuild. everything about the engine as it stands is an unknown. i can say from experience that installing an engine then pulling it back out days later is very disapointing, not to mention time consuming.
Edited by Richie on 28th Jan, 2006.
On 17th Aug, 2009 Jay#2 said:
I doubt I'll be dipping into the 13's like you did though! |
