Home > General Chat > quick shift
ben doodar
Member #: 595
stoke on trent
is there any point in having a quick shift? because i can only change gear as fast as i can slam the clutch down to the floor, so wud there be any point in it.
Carl
Member #: 95
liverpool-on-sea
i love my quick shift. id say have a feel of one.
basically what you get is instead of 1st gear to 2nd gear being 11 inches apart, with quickshift there 3 inchs appart if you know what i mean.*smiley*
jimmy
Member #: 829
essex
it is what it is a quick gear change less time on the clutch
1293 Turbo mini
ben doodar
Member #: 595
stoke on trent
what i ment jimmy, is i can change into gear faster than i can move my left foot. good point about the 11" gap thingy i suppose it makes it feel a lot tighter sort of thing. il get 1 tomorrow anyway. cheers
ben.
Ben i have one they are excellent
carl described them perfect!
it also gives a modern gearchange feel *happy*
Edited by BENROSS on 29th Jan, 2006.
hippyinamini
Member #: 520
nr hull
are the new style KAD ones any better than the old type? ive got the origional type one and love it to bits, but im gonna need one for the next project and wasn't sure if the new ones were any better?
steve
doh! why did i start messing with it!
AlexF2003
Member #: 80
AFRacing LTD
Newbury, Berks
generally wears your syncros faster.
but like people have said they feel nice!
alex
AlexF
Just going to say that Alex, as even when your going stow round town, a slow gear change with a quick shift might well be faster than you would normaly change gear. There for possible wear things quicker. That's why i haven't got one. never say never though.
CJ
Member #: 686
Lincoln
You would get to a gear quicker but its limited to how quick you put the clutch in.
Ben H
Member #: 184
Melton Mowbray, Pie Country
We have been accused of having an automatic gear box (by some loony) because our gear changes are so fast. I don't think we would be near as fast without the quick shift.
Don't forget that if you are driving properly both hands should be on the wheel before a change. So you should include some of the time moving you hand to the gearstick as time to depress the clutch.
http://www.twin-turbo.co.uk
And we don't give a shit about syncro life.
And the engine and seleter are solid mounted, which helps LOADS.
