Home > Beginners Tech > KAD Quickshift on a S/C box?
Dogmatix
Member #: 851
Hereford
Hello all.
Have been thinking about the KAD quickshift jobbie.
I will be getting a S/C C/R box for my turbo, and I was wondering if the KAD kit is ideal for it?
Also if I could ask a favor, about 2" up from the bottom, what is the total movement from 1st - 2nd? I ask as I want to make a gear shift plate... and want to know if its actully worth doing.
Thanks
When you say 'gear shift plate' do you mean a Ferari-esk plate with slots in?
If so, forget it.
I wanted to make a plate to stop accidentally grabbing reverse, but the sidways movement between gears is less than the width of the gearstick; making it very difficult to make. And making it impossible to make what I think you want.
Wil
I'd personally get the £££££ straight cut box bought, built, and in the car underneath an engine worthy of it before worrying about a pennies quick shift thing for it......
Nick
Member #: 154
Midlands
agree with wil on the gear gate idea, tried to make one for mine years ago but it just aint do-able...
Well, you could make it 3/4' above the exhaust tunnel :)
Easy!
Dogmatix
Member #: 851
Hereford
I have worried about the lower end of my turbo engine.
Ok I'll scrap the idea of the shiftgate, but will a KAD QS set, be ok on a S/C as I hear S/C boxes changes gear different to a heli box?
They change the same, they use the same shifting bits, unless you go for a dog box that is.
All that changes is the gear profile. *smiley*
Dogmatix
Member #: 851
Hereford
Oh, I thought you had to take care when changing down... I.e not droping from say 4th to 2nd... in traffic...
I thought you HAD to got 4th, 3rd, 2nd
A normal SC box {non dog} is just the same as a helical box to use.
Phil. *smiley*
Dogmatix
Member #: 851
Hereford
Whats a dog box?
It is only 5 speed boxes they say dont use a quickshift.
Paul
a dog box has no syncro's
Ram it home so they say *happy*
