Home > General Chat > oil pressure fuel pump switch made.
turbo hogster
Member #: 178
stowmaket suffolk
well spent a hour or so on the lathe with a gertain bit of hexy brass and made up a new union utilising a hydaulic brake switch to activate the fuel pump.
basicaly one end goes into my inch extension out of the block then fit the oil suplly pipe then screw the new union on the end which suplies oil to the turbo aswell as the oil gauge and the switch which is mounted on the side.
im going to use the swicth to earth out the relay when the engine starts so to start up the pump aswell im going to fit an inline switch to bypass this so you can prime carb after hot runs ect.
quiet easy to make realy and should pose some saftey after a colision.
will post a pic when i get time.
Kean
Member #: 341
aka T2clubby
South Staffs
great work m8, sounds like a very good idea
Would there be going into to production? *wink* *wink*
T3Tone
Member #: 252
Sunny suffolk
Sounds good mate, and yes alot safer in the unfortunate event of a collision
Edited by T3Tone on 1st Feb, 2006.
-MINI CLUBMAN 1380 TURBO-
A far easier way of doing this is to just use a 5 pin changeover relay, and the standard oil pressure switch that triggers at around 5psi.
If you wire it up in a certain way, you can have it so that when you turn the ignition switch to "crank" position, this primes your fuel pump to allow the engine to start, then once the oil pressure has risen, this switches the relay over and allows the pump to run as normal. In the event of loss of oil pressure your fuel pump stops.
This is how the Metro turbos were originally arranged.
Carl
Member #: 95
liverpool-on-sea
what if you crash and you engine doesnt stop!!!
if i was you id fit an inertia switch too, better safe than sorrry.
ive wired a pump up like tom says on my last mini and it worked brilliantly.
*smiley*
I believe that you aren't allowed to 'not' use an inertia switch on modern vehicles...
I'll always run one. Always.
well done Hoggy!
It is good for those without a 'bling' ecu to control the fuel pump of course - as it means you can sit there with the ignition on (engine off) and not have the pump whirring away...
jimmy
Member #: 829
essex
if you look at this wiring diagram for era mini fuel pump wiring go to TECHICAL than wiring diagram
hppt://www.eraturbo.com/gallery/gallery.htm
Edited by jimmy on 1st Feb, 2006.
1293 Turbo mini
turbo hogster
Member #: 178
stowmaket suffolk
i was going to go down oil pressure switch route but the making of my union would still be the same but decided on the hydraulic brake switch route as they switch with oil pressure and not the other way round which i thought would be easier to wire up.
but yes if the engine didnt stop then they still would be a problem but still better than no switch at all, but the inetia switch idea is also a bloody good idea but aint got a clue were to get one.
Nick
Member #: 154
Midlands
passenger footwell of a mondeo i believe. Got mine from dan i think it was when he raided a few from the scrappy...
turbo hogster
Member #: 178
stowmaket suffolk
sexual i have an old one at work ill raid it .
buy the way what does it look like.
regards dick
Nick
Member #: 154
Midlands
its a little black box with a red button in the end. get as much of the wires as possible too...
This is how to do it with a relay if anyone is interested.
pot_dan
Member #: 326
bradford, west yorks
i dident think but i could have taken the one off my mums escort before insurance took it away when i wrote it off, lol
http://turbominis.co.uk/car/105/
Carl
Member #: 95
liverpool-on-sea
and as if by magic
http://cgi.ebay.co.uk/FUEL-PUMP-INERTIA-SW...1QQcmdZViewItem
a bit dear if you go scrappy they fit in your pocket and are free*tongue*
slim_shadyuk
Member #: 703
Plymouth, On the floating skip known as HMS Albion
I believe this topic has been touched on before.
http://www.turbominis.co.uk/forums/index.php?p=vt&tid=299
Edited by slim_shadyuk on 8th Feb, 2006.
Whats going to break next!?
Turbominis Worst Advice winner 2006, get in
