Home > General Chat > O/T 1.1 metro k-series injector
Andymini
Member #: 438
London
Anyone know the specification for the injectors used on the 1.1 metro k-series engine?
I think they may be just right for a little project I'm working on.
Andy
nutter driver
Member #: 47
Not very sunny swanage
they were injected?
my 1.1 metty k series was carbed?!?!?! that was on a k plate..... maybe later ones were injected?
Andymini
Member #: 438
London
They did inject them, aye. '94 on, I believe.
Anyway, scotch it, as I've discovered they were single point injection, which isn't any good for my purpose.
Andy
Edited by Andymini on 4th Feb, 2006.
giallofly
Member #: 164
The Stig..
Newport Pagnell
I am sure the 105 bhp model was multi point.
pot_dan
Member #: 326
bradford, west yorks
1.4 gti was mpi wasent it i am sure i have read that somewere...
http://turbominis.co.uk/car/105/
jimmy
Member #: 829
essex
Metro 11i
Year 1991/95
Engine 11K2D
Fuel system Rover/MEMS/TBL-i/MAP
Trigger loction Crankshaft
output 60hp/6000RPM
(with cat)
Metro 111i
Year 1995/96
Engine K8-1.1
Fuel system Rover/SPi/TBL-i/MAP
output 60hp/6000rpm
(with cat)
Metro 111i
Year 1996/98
Engine K8-1.1
Fuel system Rover/MEMS/MFL-i/MAP
output 60hp/5700
(with cat)
Edited by jimmy on 5th Feb, 2006.
1293 Turbo mini
Andymini
Member #: 438
London
Yep, the bigger engines were mpi, but the injectors will probably be getting a little large. What I'm after is a single injector delivering about 7-10 lbs per/hr.
Bosch have a small injector in their range, but I have no idea what that is fitted in.
I want to inject a small 300cc 1-cylinder engine, which delivers about 13bhp on the standard carb.
Looking at a 1.3 Ford Ka now. That engine is mpi, and delivered about 60bhp- 15hp per cylinder sounds in the right ballpark.
Several modern scooters with EFI these days (Honda, Peugeot, piaggio...), but trying to find them in a bike breakers is like trying to find a pot of gold at the end of a rainbow.
Bigger engines are easy to find bits for- the smaller stuff is a bit more problematic.
Another option is to use a larger injector, and reduce the fuel line pressure, some have had success adopting that approach.
Andy
Edited by Andymini on 5th Feb, 2006.
pot_dan
Member #: 326
can i ask more about this engine and stuff pleeeaassee. just cos i am nosey, what is it why are you putting it to EFI and things?
Andymini
Member #: 438
London
Well, I'll probably get absolutely caned for this, bearing in mind this is a site geared towards performance minis, but it's for a 1959 BMW Isetta bubble car.
Basically a scooter with a shell around it!
With a single cylinder air-cooled 4-stroke engine putting out 13 bananas and only about 16-17 curly whirlies, it just about had enough poke to get out of it's own way.
I want to run a taller final drive for a more relaxed cruising rpm (bigger sprocket- chain FD).
Improving the torque figure is my main objective, hence my interest in injection and also mapped ignition.
Plan to use a Megasquirt V3 board, as this allows direct control of the coil, as well as giving the option of upgrading to MSII at a later date if I want to implement idle air control.
I've been plowing my way through the mega manual, quite a steep learning curve, but I'm getting there.
I'm going to visit the breakers next weekend and have a nose round at cars in the 1-1.3 litre range.
Andy
nutter driver
Member #: 47
dude, i seriously doubt anyone on here wil be on your back for doing something like that! sounds like a good plan..... keep us up to date!!
Andymini
Member #: 438
London
That was one of the places I looked.
The smallest Bosch injector at 9.6 lb per hr would be ideal. No idea what that is fitted to though (doesn't say in the list).
Honda Pantheon 125 or 150cc uses an injector that would be ace. The price for new spares made my eyes water though!
I'm thinking the injector from 1.3 Ford Ka would fit the bill. Other possibilities include Fiat Panda, Fiesta etc.
I've got quite a few options. Just have to check the local scrappies.
Andy
jamesfawcett
Member #: 218
Bingley, West Yorkshire
Is there any way i can help? my daily driver while im building the mini turbo is a 1.1 metro (carb one) i can get pics and take things apart to look?
