| Home > General Chat > Brake Bias | |||||||
8th Feb, 2006 at 10:15:38am
I was going to continue this in the wanted section, but though it warrented a new thread.
http://www.twin-turbo.co.uk
8th Feb, 2006 at 10:20:20am
1) Not sure never dismantled one.
8th Feb, 2006 at 10:37:26am
1. Some are, not all. I think the only type you can get now, is the twin bore ones. It's easily to see on the outside of the casting if they are single or twin bore.
8th Feb, 2006 at 10:46:26am
Well that has made my mind up, seems a much better way than that thing on the bulkhead, it may save weight too. It will take a bit of tuning I guess, but we can manage that.
![]() 2102 Posts Member #: 432 Post Whore Swindon |
8th Feb, 2006 at 10:58:38am
so you use them instead of the bias?
8th Feb, 2006 at 11:00:33am
I've done what vegard said, but got mine from rally design for cheaper than that Team www.sheepspeed.com Racing
8th Feb, 2006 at 11:46:00am
The master cylinder is a later type twin bore one (with the yellow tag).
8th Feb, 2006 at 12:03:46pm
The ones with the most pressure goes to the front. Forcexarea isn't it? :) On 13th Jul, 2012 Ben H said:
8th Feb, 2006 at 12:03:55pm
I have used the exact valve shown the the demon tweeks link posted by Vegard above. Does a cracking job.
8th Feb, 2006 at 12:06:43pm
On 08/02/2006 12:03:46 Vegard said:
The ones with the most pressure goes to the front. Forcexarea isn't it? :) But is that the top outlet or bottom? Decision made, we're off to buy a bias valve. Wil Fastest 998 mini in the world? 13.05 1/4 mile 106mph
8th Feb, 2006 at 12:08:49pm
Excellent, and with the £20 you have saved over the standard cast iron hunk of junk you can buy us all a pint.........
8th Feb, 2006 at 12:23:45pm
On 08/02/2006 12:06:43 wil_h said:
But is that the top outlet or bottom? Wil If you look at the cylinder you'll see it in the casting. I'm rather sure that the lower one is the front/big one. Edit: I did remember this from a while ago: http://www.minimania.com/web/threadid/6494...5/msgthread.cfm Edited by Vegard on 8th Feb, 2006. On 13th Jul, 2012 Ben H said:
8th Feb, 2006 at 12:23:48pm
Wil, here is a photo of mine
8th Feb, 2006 at 12:29:36pm
I don't think I can mount mine there, I'm sure the Blue Book says it can't be adjustable when driving. I'll check though, that might just be anti-roll bars.
Edited by wil_h on 8th Feb, 2006. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
8th Feb, 2006 at 12:50:16pm
Mine:
8th Feb, 2006 at 12:59:56pm
So, top to front, botton to rear?
8th Feb, 2006 at 01:30:28pm
Wil, can you check in the blue book for me please? would like to know if mine is ok or not Team www.sheepspeed.com Racing
8th Feb, 2006 at 01:44:09pm
top, with the smallest area to front, when you have a small area you make more pressure. so lower to rear, and top to front |
8th Feb, 2006 at 02:14:08pm
Look on ebay for those valves. I got a wilwood one new from the states really cheap. Postage is peanuts. Mines the infinity adjustable type, basically the same as jims but a newer model. Was about £35. |
8th Feb, 2006 at 02:45:48pm
One of these looks good to me. I love the guys respons to is it a wilwood unit.....
8th Feb, 2006 at 02:49:06pm
Yep looks good to me, good price too.
8th Feb, 2006 at 02:57:36pm
I got a twin master,The rear pipe is split into 2 then go's into a twin cylinder adjuster valve of a mk5 escort van(found on the rear axle) then to the brakes left and right. so I have adjustable side to side too
8th Feb, 2006 at 03:07:12pm
Why would you want them adjustable side to side??
8th Feb, 2006 at 03:13:43pm
for quick turn arounds?
8th Feb, 2006 at 03:20:10pm
Like this?? :)
