| Home > Help Needed / General Tech Chat > valves | |||||||
66 Posts Member #: 775 Advanced Member stourport-on-severn, worcestershire |
14th Feb, 2006 at 09:33:54pm
hi peeps,
If in Doubt, go flat out !!! |
14th Feb, 2006 at 09:45:24pm
I guess you mean 37 inlet and 32 exhaust. Why on earth would you use these sizes in a Turbo? You need all the meat between the valve seats you can have.
14th Feb, 2006 at 09:50:18pm
i thought bigger the exhaust vale the faster the gas out If in Doubt, go flat out !!! |
14th Feb, 2006 at 09:52:02pm
True, and also the faster the heat generated by the turbo will crack the cylinder head between the valve seats and knacker it!
14th Feb, 2006 at 11:03:04pm
jufferb you have it wrong my friend
Edited by BENROSS on 15th Feb, 2006.
15th Feb, 2006 at 10:06:40am
On my engine both the extra 2 studs for the 11 stud are 3/8 UNC.
15th Feb, 2006 at 11:38:12am
Hmmm don't think so. As the small bore heads are narrower, so I don't think there is room between the rocker cover and thermo housing.
15th Feb, 2006 at 11:46:03am
The torque setting you mentiond tom is 25ftb on the 1/4 unc bolt if my 90 year old memory serves me well
