| Home > Technical Chat > 11 studs... | |||||||
15th Feb, 2006 at 11:21:12am
Do you actually need 11?
AlexF |
15th Feb, 2006 at 11:29:14am
For the work involved (e.g. fuck all) when the engine is apart, then I can't see why you wouldn't do it for belt and braces.
Site Admin 6301 Posts Member #: 1 The boring bloke who runs this place. Berkshire |
15th Feb, 2006 at 11:58:31am
For newbies like me.. What work IS involved? |
15th Feb, 2006 at 12:02:28pm
drill holes in the block, tap them
15th Feb, 2006 at 12:45:22pm
Ah wow, that IS easy.. :) |
15th Feb, 2006 at 01:28:05pm
I'm on 9 studs... Don't intend to change anytime soon...
15th Feb, 2006 at 01:54:20pm
On 15/02/2006 11:29:14 Tom Fenton said:
For the work involved (e.g. fuck all) when the engine is apart, then I can't see why you wouldn't do it for belt and braces. I'm trying to work out if its belt and braces or just extra work for no reward... has anyone had a problem that going to 11 studs solved? Alex AlexF |
15th Feb, 2006 at 02:00:33pm
confirm it was the waterpump end but the block was found to be "low" at that end.
339 Posts Member #: 399 Senior Member Austria |
15th Feb, 2006 at 02:27:05pm
that was mine...
15th Feb, 2006 at 09:35:12pm
I have 11 stud but it's some thing i just get done, but i see the point, where they NORMALY blow is in the middle so are they doing any thing, however looking above at the pic maybe be there are?
15th Feb, 2006 at 10:15:22pm
As long as head and block are flat and true 9 studs are more than up to the job, even with standard studs/nuts. I have gone for upgraded studs/nuts as at the time i was concered about the centre of the headgasket blowing being a 1380. -MINI CLUBMAN 1380 TURBO- |
16th Feb, 2006 at 08:59:17am
On 15/02/2006 11:21:12 AlexF2003 said:
Do you actually need 11? I haven't had any head gasket problems... and in fact a quick search on the forum shows only a few threads about head gastkets in general! Is 11 studs old hat now we have decent gaskets? Alex thats BS if you do a comparison between the clamping load of 9 stud & 11 the 11 stud always comes out tops! as we are taking our engines to silly boost pressures & in some cases "large over bores" which the were not designed to be stressed to you need all the clamping load you can get even with supposedly better head gaskets. ok the 9 stud prevails but... i think this is just because its a pain in the rear to drill & tap the block & head etc, most peeps find this daunting when faced with a possible fook! up & not having the tools or the inclination or skill to do so. The reason that there are supposedly bad reports of 11 stud head gasket failure is…. the guy who has placed too much torque on the stud over the water pump housing & this causing block distorsion or at worst pulling through, rendering the block scrap. Not in JF case though
if 9 studs are ok! lets look at having say 8 or 7 or 6
the reason that the gasket blows between pots 2 & 3 is Inaudible detonation which kills this in most cases, as this is the weakest part of the gasket on a large bore motor IMO alex it’s the 11 stud all the way. you have been fortunate up to press or are you claiming higher boost figures than you actuall run! Edited by BENROSS on 16th Feb, 2006.
16th Feb, 2006 at 12:39:46pm
Ben... calm down... I asked a question ffs!
AlexF |
16th Feb, 2006 at 01:50:05pm
Have to aggree with AF Ben! You been on the sauce when you typed that? On 17th Nov, 2014 Tom Fenton said:
16th Feb, 2006 at 01:55:03pm
TD is exactly right... I was asked the question by a student of mine. I didn't know the answer, so I asked on here!
AlexF |
16th Feb, 2006 at 02:06:52pm
On 16/02/2006 13:55:03 AlexF2003 said:
TD is exactly right... Whooaaaa there sonny! You've just set a precidence; I only expressed my opinion, not a fact... Ben equally had a good point about the fact that if they are there, why not use them?
16th Feb, 2006 at 02:17:22pm
lol @ TD... I thought you were our Grur (in the spitural leader sence!) AlexF |
16th Feb, 2006 at 02:36:57pm
Grur?
16th Feb, 2006 at 02:58:50pm
Thanks for the compliment - but i don't consider myself a guru, or a grur for that matter... Just because i say something, doesn't mean it's totally correct or factual. "The man who never made a mistake, only made f**k all" as a wise engineer once told me... On 17th Nov, 2014 Tom Fenton said:
16th Feb, 2006 at 03:00:10pm
lol... fasting typing between students tutorials... lol AlexF |
16th Feb, 2006 at 05:50:01pm
sauce dave no at typed it this morning
16th Feb, 2006 at 09:56:06pm
i have had a gasked blow from the waterpump end, but it was a shit cheep copper thing and i couldn't honestly tell you if there was or was not any probs with the mating faces.
16th Feb, 2006 at 10:50:16pm
The centre inter bore region is the hottest of the three.
AlexF |
