| Home > Wanted > MPi / Auto Subframe and T25 | |||||||
193 Posts Member #: 510 Advanced Member Malta |
16th Feb, 2006 at 07:57:31am
Still looking for a twinpoint / auto subframe ot be able to fit my turbo engine a bit more forward
I donated, but somehow didn't get the label! :( |
100 Posts Member #: 745 Advanced Member Northampton |
17th Feb, 2006 at 06:54:06pm
I have an Auto subframe...
17th Feb, 2006 at 07:34:08pm
NOt to worry Dave,
17th Feb, 2006 at 09:14:43pm
Yes its from a C reg - Big bolt mounting jobbie...
Edited by icklemini on 17th Feb, 2006. |
17th Feb, 2006 at 11:00:38pm
are you sure this is what you need?
18th Feb, 2006 at 08:55:08am
And moving it forward gives you less room at thte front (obviously |
18th Feb, 2006 at 02:18:28pm
you need a slightly longer rod change on an spi subframe (ie an spi rodchange!), auto subframes are just wider so you need block spacers i think, pain in the arse really! |
18th Feb, 2006 at 04:09:40pm
Oh dear.... well I think I sourced an mpi Rod-Change, as I found an accident-damaged MPi on another forum.
18th Feb, 2006 at 05:59:07pm
There is pently of room without moving the engine forward on a mirage kit so your just loosing rad/intercooler space.
18th Feb, 2006 at 09:58:03pm
Iain, will you be tilting the engine however? I don't want to tilt the engine... the driveshafts wouldnt be too happy! I donated, but somehow didn't get the label! :( |
18th Feb, 2006 at 10:02:16pm
I dont think i'll need to tilt, got a full width bulkhead box in.
19th Feb, 2006 at 06:52:30pm
malta mini- you are panicing too much about tilting the engine, its nothing to worry about, its such a minor tilt that you can even notice it to the eye |
). Its at the front where you need the space for the intercooler etc. Its not that tight at the back plus i believe it then leaves your driveshafts running slightly out of line which isnt good.
