| Home > Help Needed / General Tech Chat > How low | |||||||
18th Feb, 2006 at 03:15:56pm
OK my Sprint ride height is pretty low but how low can you go on the front without risking popping the top balljoint out?
I seriously doubt it! |
18th Feb, 2006 at 05:15:06pm
Not sure on any figures, but Id imagine that miglias have them at either the lowest possible, or the optimum height, so might be a good rule to measure by...? "Turbo's make torque, and torque makes fun"
![]() 2102 Posts Member #: 432 Post Whore Swindon |
18th Feb, 2006 at 05:20:58pm
well i wouldnr recoment going too low as mine hits every speed bump i go over (litterally, not moving) and the today i hit a random bump in the road and it fell clean of LMFAO left cars swerving all over the place lol |
18th Feb, 2006 at 05:50:40pm
Im sure ive read about owners moving the pivot point of the top arm up higher in the subframe - quite what this does to the suspension geometry i dont know.... |
18th Feb, 2006 at 05:53:43pm
the first thign to "go" when lowering the car is the knuckle joint, it fouls the top arm and snapps, experienced this myself ona seriously low mini with no bump stops... so relievign the top arm would be a good place to start, unless ofcource you run coilovers! turbo 16v k-series 11.9@118.9 :)
18th Feb, 2006 at 06:30:17pm
On 18/02/2006 17:50:40 SumpNut said:
Im sure ive read about owners moving the pivot point of the top arm up higher in the subframe - quite what this does to the suspension geometry i dont know.... This is a route I have been thinking about actually ( I thought it was my idea, didnt realise others were doing it). What it does is change the angle of the outermost part of the top arm where the balljoint goes through, which stops the top balljoint popping out. Paul I seriously doubt it! |
19th Feb, 2006 at 06:25:39am
It also changes your effective spring rate at the front... running the arm at such a steep angle is giving a very soft, and un-progressive springrate. Bringing the arm more level will improve matters condiderably.
Edited by turbodave16v on 19th Feb, 2006. On 17th Nov, 2014 Tom Fenton said:
19th Feb, 2006 at 12:48:16pm
isnt TVRdave or whatever hes called on here performed similar modifications to his car? turbo 16v k-series 11.9@118.9 :)
19th Feb, 2006 at 03:54:15pm
We never did it but did think about it.
982 Posts Member #: 97 Post Whore Near Daventry, midlands |
20th Feb, 2006 at 09:17:53am
i've been setting my height to the engine, in that i always set the height so that the driveshafts are level/parallel with the ground. Purely for minimising transmission losses. I've seen the future and tbh its Pie
20th Feb, 2006 at 09:44:19am
I'm I-m not completely mistaken, Miglia guys machine the top suspension joint downwards so to speak. The hub gets "lower". Maybe the isn't allowed in Miglias, but Special saloon guys does it I know... It takes a lot of money to do this at least... On 13th Jul, 2012 Ben H said:
![]() 253 Posts Member #: 851 Senior Member Hereford |
21st Feb, 2006 at 10:39:38pm
Just a slight O/T question, you know the Mini Minus, the lower one...
21st Feb, 2006 at 11:39:54pm
Paul on my mini it mesures 7.5" on the front 8" on the rear, Team www.sheepspeed.com Racing
23rd Feb, 2006 at 04:56:30pm
thasts why i use metro screw in ball joints, more articulation , but are still on the limit
23rd Feb, 2006 at 08:08:25pm
^^ I knew that. Just not got round to doing it. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
24th Feb, 2006 at 07:13:26pm
also take a look at the hudd mini spares mini they have that really low Previous Engine: 1040cc Morespeed engine, 1275 turbo head T2 Turbo Mirage Manifolds Megajolt
26th Feb, 2006 at 11:53:31am
My car (i say mine but i dont fetch it for 2 weeks!) runs 6" of ground clearance i think |
![]() 1128 Posts Member #: 142 Post Whore Winchester |
27th Feb, 2006 at 07:41:33am
dogmatix minus look so low because they have a couple of inches chopped out of the shell making the shell itself lower than an ordinary mini, the suspension is the same |
) were talking about doing this before stuffing the last mini. Maybe they've done it on this rebuild?
