| Home > 998cc > Centre main Cap/strap | |||||||
20th Feb, 2006 at 03:06:09pm
Below is a picture of my centre main cap which has been machined for a strap. The problem is that, unlike 1275 caps, when the cap is machined the locating slot for the thrusts is machined off. It is apparently common practice to just use the thrusts as they are and let them float around a bit, but I have done this in the past and wrecked an engine.
20th Feb, 2006 at 03:10:41pm
Looks a good solution, when I built a 1098 based engine for my road car some years ago, I got my mate to machine a small recess in the strap itself for the thrust washer tab to locate in, worked a treat. I also got him to machine a flat on top of the strap, so I could still use the original style locktabs too.
20th Feb, 2006 at 03:18:15pm
What you're supposed to to on 998 maincaps, is to machine a 1" groove in the middle, Not remove the top completely as per 1275s.
Edited by Vegard on 7th Dec, 2007. On 13th Jul, 2012 Ben H said:
20th Feb, 2006 at 03:22:32pm
""What you're supposed to to on 998 maincaps, is to machine a 1" groove in the middle, Not remove the top completely as per 998.""
Edited by wil_h on 20th Feb, 2006. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
20th Feb, 2006 at 03:26:36pm
Yes, I made my own strap out of some fancy expensive steel. I had it ofcourse made with my own measurements.... On 13th Jul, 2012 Ben H said:
20th Feb, 2006 at 06:40:06pm
the engineer that did my strap (1275) has done it totally different to what ive seen before, but i forgot to take piccy before i fitted engine to block. he removed the minimal of material from the cap i mean minimal! made some spacers for inbetween the strap plus cap then counter sunk the bolts. does this make sence, he assures me this will be stronger and its how he does it on his own midget engines, so im going to give it a go and see how it holds up. ill try and get a piccy through the side of the gearbox for you. no longer a series, but still 1.3 turbo.
6th Mar, 2006 at 10:44:04pm
ive seen this advertised:
![]() 966 Posts Member #: 358 Post Whore Snetterton, Norfolk |
6th Mar, 2006 at 11:50:01pm
Nice and bling with all that engraving!!!! |
7th Mar, 2006 at 07:19:22pm
A guy in Norway has got such a setup. The car is not running yet however! On 13th Jul, 2012 Ben H said:
7th Mar, 2006 at 07:41:35pm
hope hes not using their centre main strap! LOL "Turbo's make torque, and torque makes fun"
8th Mar, 2006 at 11:46:43am
You don't need the strap on a turbo engine anyway! It doesn't rev that high.
8th Mar, 2006 at 01:49:00pm
fair enough you might not need a cap on a turbo motor, my point was that that cap does sweet FA! "Turbo's make torque, and torque makes fun"
8th Mar, 2006 at 01:57:28pm
that cap does do something. it does a similar thing to the flat version. its increasing the strength of the centre main. |
8th Mar, 2006 at 08:16:54pm
how? the cap over the bearings completely unsupported... Edited by joeybaby83 on 8th Mar, 2006. "Turbo's make torque, and torque makes fun"
27th Dec, 2006 at 07:13:50pm
This is how Simon has done mine:
27th Dec, 2006 at 07:40:25pm
Just like mine On 13th Jul, 2012 Ben H said:
27th Dec, 2006 at 07:57:19pm
It must be good if it meets Vegards' approval! Saul Bellow - "A great deal of intelligence can be invested in ignorance when the need for illusion is deep."
27th Dec, 2006 at 08:13:19pm
On 27th of Dec, 2006 at 07:13pm Axel said:
This is how Simon has done mine: I think he hhad these made after I told him that the way he did mine was a recipy for disaster. That looks like an excelent solution. Fastest 998 mini in the world? 13.05 1/4 mile 106mph
28th Dec, 2006 at 06:33:21pm
No no no your overlooking the easyest way! |
28th Dec, 2006 at 08:22:16pm
That was actually not that stupid.. Ha, great. I know for next time :) On 13th Jul, 2012 Ben H said:
28th Dec, 2006 at 11:05:53pm
dont be silly, that would be far too easy! "Turbo's make torque, and torque makes fun"
However, I did file the grooves. That took bloody ages.
